Question about Garden
Repair weed eater
When I push the primer bulb on my weed eater I don't think it's getting gas. How do I fix this?
    Sergeant:
  • 458 Answers
If you see gas in the primer bulb it is pulling in gas to the bulb. If not check for cracks in the bulb assembly and check to see if the fuel lines are not off their fittings and not cracked.
Posted on Jan 27, 2014
SOURCE: Echo weed eater, edger and blower wont start.
TRY TAKING THE MUFFLER OFF AND CLEANING THE SMALL SCREEN OR JUST REPLACE THE SCREEN
Posted on Jun 06, 2009
  • 14 Answers
SOURCE: I have weed eater model FX26SC it starts and when ...
Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
Posted on May 20, 2010
  • 4088 Answers
SOURCE: I have a poulan 2450 chainsaw and i can't get the
You may be overfilling the tank somewhat so that expanding fuel (from engine heat) is being pushed out of the vent. Check the fuel filter for plugging and all of the fuel lines for any rot, splitting, or other damage. The primer bulb is supposed to pull fuel from the fuel filter, then through the carburetor and on to the primer which should push the excess back into the tank through another line. If the above does not allow the primer to pump fuel, then dismantle the carburetor, clean with carburetor spray cleaner, and rekit it. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--theory and troubleshooting. This information applies to most brands of carburetor. Hope this gets you running!
Posted on May 31, 2010
hondakilla
  • 129 Answers
SOURCE: I have a push mower with a briggs and stratton 3.5
Take the fuel bowl off the carb and check the metering valve to make sure it opens and closes sounds like its closed not allowing fuel through the carb. Its a quick easy and very cheap fix....
Posted on Jul 11, 2010
  • 2239 Answers
SOURCE: McCulloch 28cc Gas Blower MB3200,
The primer should pull fuel out of the carb, into the bulb and dump it back to the tank, if the fuel filter in the tank is blocked, or the fuel hose is split no fuel will enter the carb, so the primer will not fill, replace the filter and the fuel hose.
Posted on Jun 01, 2011
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I I need the little plastic gas plunger for a Poulan Featherlite Plus weed eater
The part is called a primer bulb if it is mounted on the carburator or if it is a remote primer it is called a primer pump. Check with a full service dealer in your area if you have one. If you
can not find one in your area contact southern supply company at
205-833-2525 or email them at southern.supply@mindspring.com
and I feel sure Jason or someone there can help you.
Sep 13, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My weed eater will not start
Sounds like the carb or gasket around the carb is leaking allowing the pressure to blow by when you press the primer bulb. If its not air tight it will not pop back out. Check your carb and surrounding gaskets and check for a leak.
joe
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
