Stannah 420 installation manual
I have a stannah 420 stairlift. It has a copper strip that runs down the back of track where two copper brushes slide on. How do I hook the wires from my 110 volt charger. It appears on wire (black) clips on to copper strip. The red wire has a flat male push in. Where does it connect. Thanks, Forrest
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
JDeRuvo
  • 48 Answers
SOURCE: I lost my manual on hooking up the wiring on my nforce3-a motherboard.
Chances are, you can download the manual from the website of the manufacturer. That's probably the smart move. Last thing you want to do is try and do connections without it. That's a quick way to go through more than one.
JD
Digital Advisor
Posted on Dec 01, 2007
  • 243 Answers
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
map9966
  • 2351 Answers
SOURCE: Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Posted on Sep 13, 2008
teknowolf
  • 207 Answers
SOURCE: connecting startup leads to ABIT NF7 motherboard
Below is a link to the manual for this motherboard, It should be able to show you where each of the leads on your dislocated panel wires go to.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=8&product_name=NF7
Hope this helps
Thanks
Dave
Posted on Nov 20, 2008
Have there been any recalls' on Acorn Stairlifts?
Acorn Stairlifts Recalls Motorized Stair Lifts ' CPSC.gov
https://www.cpsc.gov/Recalls/2015/Acorn-Stairlifts-Recalls-Motorized-Stair-Lifts/
  1. Cached
Jul 21, 2015 - The following versions of the Acorn Superglide 120 are being recalled: Acorn 120 Stairlift, Acorn 120 Outdoor Stairlift, Acorn 120 Superglide Stairlift, Acorn Outdoor Stairlift, and Acorn Slimline Stairlift.
Acorn Stairlifts (Canada) Inc recalls Acorn 120 straight stairlifts - Health
healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2014/41513r-eng.php
  1. Cached
  2. Similar
Sep 26, 2014 - Acorn 120 Straight Stairlifts. Product description. Acorn 120 Superglide straight stairlift, installed on staircases which are straight, manufactured between March 2007 and March 2011. Hazard identified. The seat post weld may be defective. Number sold. Time period sold. Place of origin. Companies.
Acorn Stairlifts USA Recall Information
www.acornstairlifts.com/blog/post/184/News/Recall-Information:-Acorn-Stairlifts
  1. Similar
Jul 21, 2015 - Notice and Information To Consumers On Free of Charge Stair Lift Seat Post Replacement.
Acorn Stairlifts Recalls 34,500 Models After Reports of U.K. Deaths ...
www.nbcnews.com/.../acorn-stairlifts-recalls-34-500-models-after-reports-u-k-n3963...
  1. Cached
  2. Similar
Jul 22, 2015 - Around 34500 stairlifts have been recalled in the United States following reports that two people were killed when the chairs fell apart.
Top 96 Complaints and Reviews about Acorn Stairlifts
https://www.consumeraffairs.com > Homeowners > Stair Lifts
  1. Cached
Rating: 1.1 - ‎36 votes Jan 2, 2017 - How do I know I can trust these reviews about Acorn Stairlifts? ..... is not one of the recalled units" and then it was click and she hung up. recalls on Acorn Stairlifts Google Search
Jan 12, 2017 | Televison & Video
How to connect the battery charger to the stairlift on my stannah 400 stairlift
I'm not completely sure but I suspect there is a socket on the end of the rail, one at the top and one at the bottom.
Jun 12, 2016 | Miscellaneous
I need the details of servicing a Stannah 420 stairlift
hi, one of the main things for the 420 is the replacement of batteries if the stair lift is slowing down , also make sure the charger is working correctly...and keeping the chair at the very top or bottom so the batteries are on charge ready for use...
Checking the brushes, looking at less than 50% wear, making sure there are no large build-up of carbon, if so clean the motor brush area using a electronic contact cleaner .. looking at the teeth on main gear making sure it is clean free of dirt etc..
Looking at the brake that is located on the end of the motor making sure once again it gripping and the chairlift once it has stopped does not slip or move slightly ...Electronic contact cleaner here if you feel it dragging, a nice loud click is required here as that's telling you the brake is running freely...
Regards
Mick
I would always advise a professional to service the stair lift on a yearly basis...
http://www.southeaststairliftservices.co.uk/
May 15, 2016 | Cars & Trucks
Try here http://stairlift-forum.co.uk/forum/main-category/stairlift-user-manuals-technical-brochures/163-stannah-420-stairlift-saxon-straight-stairlift
Mar 02, 2015 | Cameras
Is this the link you are looking for?
Link to manuals for the Stannah star lift 420
Please put your questions in the right category. This was in Digital Cameras. Never saw a lift making any picture.
Nov 16, 2013 | Cameras
According to one of your solutions rergarding a noisy k45 kitchenaid I removed the brushes to examine and upon multiple attempts to reinsert properly - the noisy machine no longer operates to make noise. ...
Hello; Bummer trade off, huh? Ok , here we go.Getting it to run again, then address the noise. The attached drawing shows how the brushes should be installed. The brushes take a set and must be placed back into the same holder and leading edge into rotation, set square on the armature, w/full contactand spring pressure. After Slidingthe brush in place, lift it slightly and let it drop back onto thr srmature. Not much and let the spring set the brush and align .You want to make sure the brush moves smoothly up and down. The part the brushes ride on is called the the commutator. The copper bars. Each is separated by a thin piece of mica. If there is any copper bridging the mic, the motor will be noisy and not run smooth. In this case, use an ice pick to scratch the mica so it's below the copper ba abou, never mind, just run the pick down the mica groove to keep the bars seperated. Put it all together and turn it on. You may have to tap the motor to get it going. Once it gets going let the motor run for about 15 minutes at high speed and 5 minutes at low speed, Good luck and take caution not to get shocked. I'm here so feel free to keep in touch. 909-630-3192. Ned
Apr 16, 2011 | Microwave Ovens
I need to replace batteries on a Stannah Stairlift model 300, but I don't know how. Please help!
As you sit in the Stannah seat on your right side just under the seat is a lid that pops down. There should be two batteries. There's a metal band that holds the batteries in place, a slot on the side of the batterie case lets you press in with knife blade or whatever fits the slot. Be sure when instaling new batteries that you get positive to positive and negative to negative.
Feb 23, 2011 | Health & Beauty
How do I intstall a black ink cartridge in a hp desk jet 5550 printer?
Follow these steps to install the cartridges. Step Example
  1. Make sure the product is on.
  2. Open the top cover. Wait until the carriage moves to the center of the product and is idle and silent.
  3. Open the cartridge latch.
  4. If you are replacing the cartridge, slide the old cartridge out of its slot.
Figure 6: Open the product and remove the old cartridgec00160484.gif Remove a new cartridge from its packaging, and then carefully remove the plastic tape. Hold the cartridge so that the copper strip is on the bottom.
CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 7: Remove the protective tapec00160485.png
  1. Slide the cartridge firmly into the cradle. Make sure that the copper contacts of the cartridge meet the copper contacts inside the printer.
  2. Press down on the cartridge latch until it snaps closed.
  3. Close the top cover.
Figure 8: Insert the new cartridgec00160486.gif
Nov 03, 2010 | Office Equipment & Supplies
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
