posted by IThelp on Aug 28, 2007
Hello ,
I have a Datalogic Dragon D101 with based with PS/2 port. I try to connect using a simple ps/2 to USB then using a usb extension wire to connect the barcode to USB port located in the PC. But it seem like it will not work this way. Why? How can I connect my PS/2 barcode scanner to a PC USB port?
1 Other User Has The Same Problem
Comment by bbarrow, posted on Feb 03, 2008
i am doing the same but using rs232 to usb adaptor i can send data to the reader but no output i tried to use a comport to keyboard buffer redirector with no luck.
Solution #1
posted on Feb 04, 2008
i connected it to a laptop using a usb to serial adaptor and bc-wedge serial to keyboard buffer application . i could send data to the reader but not get anything from it. i figured out that i did not bind the reader to the cradle as it says on page 7 of the quick reference book, it works great now any barcode i scan goes where i want it to .... i also connected it to a pc without using the usb adaptor thru the 9 pin serial cable and using the bc-wedge and it works with no problems ... had to make sure com port settings were the same 9600 8 none and 1 in windows and bc-wedge or the output is gibberish..hope this helped...
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 23, 2007
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc.
You would also have to use the correct scanner codes to ensure that the scanner is configured properly.
Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem.
If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Suggest a new solution for this problem
Post a New problem for Datalogic Dragon D101 Portable
Email this problem
Email this problem
Can you Help with these Barcode Scanners problems?
Repair Service
Find Barcode Scanner Repairman Near You:
