Sony kv g14q1
GOING TO STANDBY MODE AFTER SEVERAL TIME
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
SOURCE: Sony Trinitron 2002 model # KV-32HS500
Mine never blinked 7 times but 6, 5, 4 times Yes
Posted on Jan 18, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 4090 Answers
SOURCE: sony wega KV-36FS13 standby light blinking 5
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
Posted on May 20, 2010
SONY TV trinitron modle: kv g14q1. when I start the tv on after the few seconds it become off in standby position, plz help me!
Might be faulty capacitors - impossible to tell but for problems like these you will need to take it to a repair shop.
Mar 05, 2014 | Computers & Internet
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-36fs320
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Sep 21, 2008 | Sony FD Trinitron WEGA KV-36FS320 36" TV
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA® KV-BM142M40
press sequently (1) display (2) 5 (3)volume+(4) power or TV when tv in standby mode
Nov 11, 2007 | Sony WEGA® KV-BM142M40 14" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
