Question about Nordic Track C900 Pro
Taking apart move - Nordic Track C900 Pro
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
You must follow the steps indicated in your owner manual, please read carefully. or download free
www.fitness.manualsonline.com
God bless you
Posted on Jul 18, 2013
Brother take apart
Hello
Before you take the machine apart, check that the bobbin winder is not engaged and that the fly wheel is locked in place. Both can be done without taking the machine apart.
Happy Stitching.
Aug 06, 2014 | Brother LS-1520 Mechanical Sewing Machine
I put too much carrot skins down the disposal , the blades turn but the water will not drain
You have to take apart the tubular drain pipes located under sink.
It will be fun.
Here's some do-it-yourself information to save calling plumber.
Take apart tubular pipes and clean them out.
Take a photo of the drain before starting. Take other photo as needed for facebook.
Once pipes are apart, run water or use coat hanger to clean out disposal.
Not necessary to take disposal out.
1) Tubular pipes connect to disposal.
Each tubular pipe has a nut and washer.
Pipes can be metal with rubber washer.
Pipes can be plastic with plastic washer.
2) Tubular pipes come apart with channels locks
3) You need a bucket to catch the water when you take apart tubular pipes.
Keep towel handy.
4) All tubular pipes that get moved while working under sink have to be taken apart, cleaned and re-assembled. All you do is take them apart, clean them out, clean them up, and re-assemble the same way they came apart.
5) Take a photo of the drain assembly before starting. Always start with the P-trap shown image above. Loosen top nut and lift up nut. Next, loosen tubular pipe that connects to disposal. and see it can lift out of P-trap without moving any of the other pipes. If clog is inside p-trap, then p-trap will have to come off. Try not to move any other drain pipes; any drain pipe that gets moved will start to leak and needs to be taken apart, cleaned and re-assembled.
6) For best results:
After clog is removed,
Clean all tubular pipes and washers before re-assembly. Take photos as you go so you know where each part goes.
Plastic washers are re-used.
Flat part of plastic washer fits against nut, tapered part away from nut.
Rubber washers can be re-used depending on age >> new rubber washers are best.
7) To re-seal tubular pipes first-time every-time, use rectorseal on rubber or plastic washers.
As you are re-assembling, smear healthy amount over entire washer and then tighten the nut.
Wipe off excess on outside of pipe.
Add a comment if you have a problem.
Nov 21, 2010 | Electrical Supplies
MT THERMAL HEAD IS STUCK IN THE DOWN POSITION AND I CANT GET THE HEAD TO MOVE BACK IN PLACE , WHAT COULD BE WRONG
try to take it apart, and move it back. take the whole printer apart. and make sure everything is in place
Jun 19, 2010 | Sony UP D50 Thermal Label Printer
Can't get primer to move gas thru carb on a tb70ss. what do i do/
just take carb apart pretty simple to take apart. it has probley been awhile since it was last run right? the carb is gummed up need to take apart and use carb cleaner real good
Jul 08, 2009 | Troy Bilt Tb70ss Gas Trimmer
How to detach the screen from the base.
Here is what I did on my last 2 moves with a 22" LCD.
Just wrap it in soft blanket like velour or a comforter and put it in a box so it doesn't move around. You could take off hte base but usually at risk. Most of those bases clip on and aren't really easy to slide out or meant to take back apart. You risk more damage taking it out apart then just wrapping it securely and putting it in a box.
May 29, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
Taking apart PSP
This is how to take apart ur psp http://www.youtube.com/watch?v=EFlowWbAENI the video is not mine
Sep 21, 2008 | Sony PlayStation Portable (PSP) Console
Nordic Track C900 Pro Logo
169 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
