Question about ATI RADEON X1650 Xt, (256 MB) Graphic Card
Help!!! i think i have a problem: when i run a game with good grafic ( FEAR,PREY,....), a red light on the video card (HIS ATI Radeon x1650XT) lights up; i had a source of 400w (a cheap one); might the source be the problem???
  • felixXx Aug 28, 2007
    no, the max temp. is 62 C, (when i play all the day), i had just 1 video card on AGP 8X,
Turn down the settings of your game (graphics) I have found these cards sort of just STOP if overloaded and 'stressed'. Start from the lowest setting and test. If okay go up a notch and test. If okay repeat this... But to be fair, on that card you should be able to get to quite high with the graphics. If this is okay, turn down the resolution on the game from 800x600 and then 1024 x 768 (optimal up to 17") then 1280 x 1024 (optimal 19" and above) and if applicable 1600 x 1200 Have you had it long? You could always get a replacement if still under warranty! I have had 3 X1950's and yours is the second X1650 I have heard about behaving in this matter.
Posted on Aug 28, 2007
    Novelist:
  • 231 Answers
Hi its unlikely to be your power supply,more like the video card is over heating, vent your case and add an extra fan and see if this cures the problem, Also if you have another pci card beside the video card, move it aside too allow better air flow and less interference to the v/card. Regards mistyman
SOURCE:
Input Lag in video games, ATI Radeon 3600 graphics card
I just looked at my machine and i see the ATI HotKeyPoller I go to control panel then administrative tools then services but I have XP not vista. Many querks about vista. Maybe something to do with the drivers for that ATI cards. Have you checked for newer releases from their web site. Or maybe just remove and reinstall the drivers. If this helps please reply-that helps me continue top answer questions here and good luck
Apr 29, 2010 | ATI RADEON Graphic Card
Graphics card overheat-Radeon X1650XT
u need to remove the graphic card, open the fan and the copper layer and change the thermal layer on the GPU then clean the fan and put little bit of non sticky oil on to it and fit it back properly ... ur issue would be fixed for sure :)
Jan 11, 2010 | ATI RADEON X1650 Xt, (256 MB) Graphic...
My HIS Radeon x1650XT hangs after playing 3D Games.
change your graphics card or you may upgrade your card.
Jun 03, 2009 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Problem with Ati radeon graphic card
The ATI Radeon X1050 video card is unfortunately not supported by the game. You need atleast a X1300 to play the game. But you may try updating the game itself by going to the medal of honor website and download the patch. Then restart your computer and try starting the game.
Nov 07, 2008 | HIP Medal Of Honor: Airbourne for Windows
Program won't run, error message says it can't find 3d software.
If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
Recommended System Requirements:
- 3 GHz Intel Pentium 4 or equivalent processor
- 1GB System Ram
- ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
1.2. Minimum System Requirements
Minimum System Requirements:
- Windows XP
- 512MB System RAM
- 2 GHz Intel Pentium 4 or equivalent processor
- 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
- CD-ROM or DVD-ROM drive
- 4.6GB free hard disk space
- DirectX 9.0c (included)
- DirectX 8.1 compatible sound card
- Microsoft .NET 2.0 Framework for toolset (included)
- Broadband connection for multiplayer online play
- Keyboard, Mouse
1.3. Supported Video Cards
- ATI Radeon X1900 series
- ATI Radeon X1800 series
- ATI Radeon X1600 series
- ATI Radeon X1300 series
- ATI Radeon X850 series
- ATI Radeon X700 series
- ATI Radeon X600 series
- ATI Radeon X300 series
- ATI Radeon 9800 series
- ATI Radeon 9600 series
- ATI Radeon 9500 series
- NVIDIA GeForce 7900 series
- NVIDIA GeForce 7800 series
- NVIDIA GeForce 7600 series
- NVIDIA GeForce 7300 series
- NVIDIA GeForce 6800 series
- NVIDIA GeForce 6600 series
- NVIDIA GeForce 6500 series
- NVIDIA GeForce 6200 series
- NVIDIA GeForce 6100 series
- NVIDIA GeForce FX 5900 series
- NVIDIA GeForce FX 5700 series
- NVIDIA GeForce FX 5600 series
- NVIDIA GeForce FX 5500 series
Oct 28, 2008 | Video Game Consoles & Games
I can't play Prey on my new fancy card...
You can try and install the latest patch to the game here:
http://downloads.gamezone.com/demos/d20976.htm
Also make sure you have the latest drivers for your video card.
Hope this helps!
Mar 24, 2008 | ATI RADEON X1650 Graphic Card
The game stopped
Hello matbedui,
If you think the Radeon card is overheating you can check this by simply touching the card after it's been running for sometime. Some Radeon cards (high end) do have this problem. PC cases that do not have sufficient fresh air flow cause problems not just to video cards but to everything inside the case. The design of the HIS Radeon X1650 is less than sufficient. Keeping air flow contained. One way in & one way out. This issue is so important many companies creat sites to help you cool your card.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=196
Your Radeon X1650 Pro IceQ II runs ATI's chips. Installing the latest software is recomended. Download from here:
http://ati.amd.com/support/driver.html
Pick your OS. Than pick Radeon. Scroll down to your X1600 series. You can also update through HIS. Their software is twice the size of the ATI software.
http://www.hisdigital.com/html/driver.php?id=64
Feb 24, 2008 | HIS RADEON X1650 Pro IceQ II, (256 MB)...
Graphics Card
My bad, i was going to just ask about your PSU and went on trying to fix your problem :) If you do download rivatuner, check how hot your graphics card is running in graphics intensive games (it has a chart recorder). BTW I have a 1600XT and speeding up the fan helped a lot!
A.J.
Jan 23, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
Open Questions:
See all ATI RADEON X1650 Xt, (256 MB) Graphic Card Questions
ATI RADEON  X1650 Xt, (256 MB) Graphic Card Logo
61 people viewed this question
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
