I have a heavy duty capacity 8 cycle 2 speed admiral washing machine. It just suddenly quit working. It quit working on the rince cycle but is still full of water. I tried other cycles & nothing. It was working just fine prior to this. No strange noises or anything. Trouble shooting ideas???
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
  • 209 Answers
SOURCE: my washing machine is full of water!!!
check pump for open circuit electrically, if that is fine and the pump works but just doesn't drain then its a blockage somewhere between the drum and the waste outlet, strip the pipes and clean out, taking care to note original position of any parts and wires etc
Posted on Oct 14, 2007
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
SOURCE: I have an admiral heavy duty super capacity plus 2
load lite, and if the problem still is there let run empty a couple of times, if there is still a problem it is off track and a professional needs to go inside of it you can do it yourself but not recommended so call a pro!!!
Posted on Apr 21, 2010
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
I have an admiral heavy duty super capacity plus 2 speed. I hear a grinding sound when the washer is washing whats the problem?
Apr 21, 2010 | Admiral AW22 Top Load Washer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Won't spin or agitate
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
Aug 12, 2008 | Frigidaire Washing Machines
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
