Dupli Carver F200 - Audio Players & Recorders
LOOKING FOR SIGNET SILVER SPRAY PAINT FOR MY 2001 HONDA ACCORD
So an auto parts store that carries Dupli Color can't supply it or order it?
Apr 21, 2013 | Dupli-Color Acura/Honda Metallic Starlight...
User manual for carver 6250 receiver
I'm looking for parts to repair Carver 6250, as I turn volume up or down the output has some distortion.
Jan 30, 2012 | Carver Audio Players & Recorders
Need a user manual for a Carver PM 1.5 Magnetic Field Power Amplifier
try this -> http://www.acousticpsychos.com/Files/Carver/carver-pm1.5-pwr-om.pdf
Mar 12, 2011 | Audio Players & Recorders
Bridging Carver AV860X
AV860 is coming up with bupkus.
Bridging instructions are usually marked on the back. Typically, move a switch and connect the pair's positives to the speaker.
Mar 31, 2010 | Carver PM950 Amplifier
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Dan
Sep 04, 2009 | Carver PM950 Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Carver M-400a schematic
You are not likely to find any Carver stuff for short money. What is the problem you are trying to solve? Maybe you don't need a schematic.
Dan
Jun 11, 2008 | Carver Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
