Question about Tappan Kitchen Ranges
Tappan 11-1153-30 I am looking for an owners manual... Specifically I need to replace the light & it broke off inside the oven. There is a part called a receptical that is outside the light near the base... I'm unsure if it screws off or not
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Posted on Oct 03, 2008
duby1990
  • 367 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
  • 31 Answers
SOURCE: oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Posted on Mar 13, 2009
  • 77 Answers
SOURCE: Inside oven door glass broken
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Posted on Apr 17, 2009
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
TAPPAN GAS RANGE MODEL NUMBER MPF500PBWD
the owners manual will not give you any repair info. Only use instructions. Your model has an oven safety gas valve that opens only after the secondary pilot heats the end of capillary properly. You may need to clean/replace the pilot assembly OR replace the oven safety valve. If you need the valve, look on ebay because these things are over $275 from Tappan.
Aug 21, 2014 | Tappan MGF500PBW Gas Kitchen Range
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
Mar 17, 2013 | Tappan Ovens
Tappan Convectionaire stove with built in microwave. Purchased in 1985. This is the 4th time the handle on the microwave door has broken off. We were able to replace it in the past, but I cannot find it...
we have the same tappan oven/microwave combination. We are looking for the knobs for this. Its a great oven, but we need these parts. Our microwave handle broke a long time ago and we had one made from wood. If you are going to ditch the old oven would you be willing to sell the knobs?
Aug 25, 2010 | Tappan TMT104E1 Microwave Oven
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Need owners manual for Tappan TGF334BCWb oven
Looking for Owner manual for a Tappan Gas Self Cleaning Oven Range - Model No. TGF 365BEWB
Nov 14, 2008 | Tappan TEF242 Electric Kitchen Range
Feb 04, 2008 | Kitchen Ranges
Kitchen Ranges Logo
35 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
