Motherboard pg720 ID NUMBER SMD CHIP SERIAL PORT V.24
2 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: I NEED THE MOTHERBOARD PART NUMBER/SERIAL NUMBER
try go to ebay
http://shop.ebay.com/i.html?_nkw=hp+dv9000+motherboard+&_fscr=1&_trksid=p3286.c0.m19
Posted on Apr 03, 2010
I need smd ic no mp14820s it is in dsl -2640u board
The number is MP1482
also check BD9328AEF
http://www.monolithicpower.com/Lists/Product_Synchronous%20Switcher_5717/DispForm.aspx?ID=97
Oct 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Hi there? My HP nc 6320 doesn't charge, I came to know that the IC in the power supply on the motherboard has shorted and it is dead, so what can I do? the power doesnt come into the motherboard but...
that is new mobo time, the charge or any reg chips bad.,
is the size of 1/8 of a baby's pinky finger nail
and has solder ball bottom SMD , tech.
you will never replace it and make it work again'
at home.
id give that a 1 to 1000 shot. success.
ever work SMD before?
new mOBO time, ask any tech, same answer.
have you removed all mobo modules first, to prove this case.?
any module can short, remove them all.
mine has 7 to pull.
http://www.pcdied.com/765-quad-core.jpg
Nov 12, 2017 | HP Compaq nc6320 Notebook
How can I find the part number for an HP laptop motherboard without opening the computer itself? the motherboard needs to be replaced and we need to order the part online.
You can not know the motherboard serial number it-self without opening the computer... But you have your product ID and computer serial number on the back of the laptop. That should give you, at the HP Support web-page, the drivers list for your specific built. Knowing the driver, you can know what chip-set it's holding, and so, the motherboard also.
Jun 24, 2011 | HP DV9815NR Pavilion Laptop
How do fi find my mother board serial number
The Serial Numbers of ASUS Motherboard will be 10 or 12 alpha numeric digits.
The serial number will NOT start with a ZERO ("0") or contain spaces or dashes.
Format of the serial number:
  • 1st digit: Last digit of year manufactured
  • 2nd digit: Month Manufactured (1-9, A-C)
  • 3rd digit: Product Code ("M" for Motherboard)
Possible Locations:
  • Parallel Port
  • Side of PCI Slot
  • Side of Power Connector
  • Underneath / Backside of Product
  • Side of CNR Slot
Look on your board for a white sticker as indicated by the image attached. If it isn't there, check to see if there is something actually printed on the board usually around in the same area as your BIOS chip is located.
For examples see the pics below:
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | ASUS P5N32-E SLI PLUS (0610839148967)...
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Jun 01, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
I have intel dg31 chip set , i didnt got a serial port with it so i put a anothewr serial port on it (one which was in ma old pc) but when i connect serial port with ma hardware it doesnt detect hardware....
Who is the manufactor of the serial port your adding in and also did you confirm with the motherboard manufacture that adding another serial port is possible. You may just be missing drivers or not have it setup properly. It will not come up as found new hardware. This is something that will need to be done manually. If you can confirm all this your motherboard diagram should tell you were to plug it in and how to from there on it should just work unless something is turned off or miss configured.
Mar 17, 2009 | Intel DG31PR Motherboard
I want UNQUIE CPU ID NUMBER FOR MY CPU (20-11-08)
OK you will need to enable the CPU serial number feature in the bios (if your bios supports it)
or
You can download the Intel Processor Serial Number Control Utility from Intel here: http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=24&DwnldID=823&agr=Y&lang=eng&PrdMap=24
let me know if this info helps
thanks
Note: Check bios first for option because the utility above may not work if the option is disabled in your bios. (if your bios does not have that option then utility should work fine by itself)
Nov 20, 2008 | Intel Server Board S5000PSL - Motherboard...
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
