Question about HP Hewlett Packard - 5187-7590 - This 5187-7590 Is A Genuine Remote
Re HP 7590 printer - "printer status error" in Control Panel
Had paper jam in printer, sorted out jam but now when I send something to print it wont print and in my Control Panel on Computer says "Printer status - error" but it still will act as scanner?
    Top Expert:
  • HP Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2ZOUHvWVn
Posted on Jul 18, 2013
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
Feb 08, 2011 | HP LaserJet P2015dn Printer
My hp 2360 wont print, green light keeps on blinking, it says printer offline on the printer status bar
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means
The Power light can flash for several reasons:
? The printer cover is open.
? The printer is out of paper.
? A problem exists with the printer, such as a paper jam or a problem with a print
cartridge.
For information
Jan 30, 2011 | HP Deskjet 2360 InkJet Printer
I had a paper jam and cleared it. Now the power light and paperfeed light are on and won't go off. I cannot print nor turn off the printer via the buttons. I have reinstalled drivers, opened the back panel...
What precisely IS the error message? In lieu of this information, unplug the printer. Check the paper path thoroughly including between rollers. Any tiny fragment will jam. Use a falshlight and magnifier if you must. Load with normal thickness printer paper. Plug the unit in. Hold the power button down for 10 seconds. Test page should print.
Oct 21, 2009 | HP DeskJet 1220c InkJet Printer
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
OfficeJet Pro 7590 cuts off last line
Check the format of paper.If it "letter"may have this problem.Change to "A4" and try again.
Oct 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
Sep 08, 2008 | HP LaserJet P2015dn Printer
HP Hewlett Packard - 5187-7590 - This 5187-7590 Is A Genuine Remote Logo
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
