Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsubishi pin and barrel issue
I have a mitsubishi 60 inch RP that has a pin and barrel issue, only its occurring at the top and bottom of the screen instead of the left and right sides where I normally see this issue. I suspect horizontal output transistor may be failing.. but not sure. The blue CRT is out as well. TV was working great the night before and now it is having these issues all at once.
    Genius:
  • 1,694 Answers
PVAT!Check for CRT coolant leak on PCB's. SOLDER ANY/ALL BAD CONNECTS. Replace convergence IC's,re-align.
Posted on Sep 28, 2007
Mitsubishi 60 inch dlp projection tv has huge black spot on the bottom of the screen
try cleaning the lens & mirror, there may be something in there. other wise may need a new light engine. If the light engine is what's causing the issue, recommend replacing the TV with a NEW LED or LCD TV, due to costs.
Jul 19, 2014 | Televison & Video
NEED FRONT SCREEN THAT FITS OVER SCREEN
I'm trying to remove the screen from mine, do you have an owner's manual that shows how?
Jan 12, 2010 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
