Question about Exercise & Fitness
I have the Roger black treadmill and need to know the screw sizes that hold on the tread mill on the roller at top end of machine as mine come loose when running and then the belt slides of the motor..,,,, can any one help
    Top Expert:
  • 12,223 Answers
You need to Read the owner manual, in the section for assembly or dissasembly they appear the screw sizes needed for any section.
or download free from www.fitness.manualsonline.com +
www,retrevo.com
God bless you
Posted on Jul 18, 2013
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
SOURCE: roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Posted on Dec 01, 2009
  • 103 Answers
SOURCE: sounds like bearing loose inrear of tread mill
It sounds as if your rear roller may have a bad bearing. The bearings themselves are not replacable. The entire roller must be replaced. You can find the parts lited on iconservice.com and enter EPTL09706 in the model number box under the "replacement parts" section of the site. This replacement can be done easily using normal home hand tools.
First remove power to the machine.
Second put the machine into space saver mode. (latched in the up position)
Third go to the rear of the machine and locate the 2 wheels on the rear. There is an allen screw with a nut holding the wheels in place.
Fourth there are 2 screws holding the wheel bracket onto the end caps of the machine.
Fifth there are another 2 srews holding the endcaps onto the frame assembly.
lastly you will be able to locate the two bolts holding the rear roller in place. First mark the bolts where they connect to the actual roller with something so you can see how far to tighten the bolts back onto the new roller. remove the old roller...install the bolts onto the new roller then tighten back down to the marks you made on the bolts.
reverse the process for removing the other brackets.
If after replacing the roller your belt is not straight you may adjust it by this procedure.
If the belt is tracking to the right Then access the right allen screw located on the rear of the machine that connects to the rear roller.
Rotate this bolt CLOCKWISE 1 full revolution. This should move the belt to the left.
Do the same procedure except on the left if the belt is tracking to the left.
Good Luck! Tim
Posted on Dec 16, 2009
  • 16 Answers
SOURCE: belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Posted on Feb 20, 2010
How do I replace a tread mill belt
Not a small task. You have to remove rollers and deck if you are doing this flip your deck as it is probably due and clean rollers since you have everything apart. Good luck
Jul 15, 2014 | Weslo Cadence Lx25 Treadmill Walking Belt
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
Mar 21, 2013 | Landice L8 80 LTD Executive Trainer...
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
Hi my tread mill has stopped working i could smell burning from the mortor and it was warm the seriel no is 200604 and the dc mortor model no gmd 118-1 its make is roger black can you help please
Dear Sir:
The problem can be various factors;
1) Lack of lube in deck belt( maybe is worn, and need replace)
2) The drive belt is worn, or break and need replace.
3) The main motor bearing is bad.
4) The main motor winding is burn and need repair or replace.
5) The rollers bearing is bad need replace and lube.
Take care of this, and take the step for repais in any Item
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
Sounds like bearing loose inrear of tread mill
Good Luck! Tim
Dec 15, 2009 | Epic View 550 Treadmill
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Treadmill adjustment on bowflex 5000tc
There are two hexagonal screws on either side of the front rollers, and four inset hexagonal screws on the back rollers. Turn it on the lowest speed while turning the ones in front, one at a time. You'll see the tread move from one side to the other. Tightening the screws bring the rollers out, pulling the rubber tread taught, and to the left or right, depending on which screw you're turning at the time. The treads should roughly be the same tension, adjusting both inside and outside front screws for each tread. If you have the dual rear rollers, you'd then have to stop the machine after finishing the fronts and tighten the four inset hexagonal screws on each of the rear rollers. No adjustment per se, just tighten them. If you don't, you'll have a sort of clunking, or clicking noise from the imbalance. The single rear roller is a little different, and the adjustment I believe, can be found on this site:
http://nautilus-technics.com/
Good luck.
Dec 28, 2008 | Bowflex Treadclimber
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Exercise & Fitness Logo
118 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
