Sonic tv remote-my tv stays blank for about an hour before it shows how do i change this
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Posted on Jul 18, 2013
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Hiteker tv codes
i have white screen on this tv no matter which input it could be on cable /tv or hdmi, dvd,etc tv stays on white screen but audio is good.. how do i fix this??? the tv dont show channels changes or setup when using control just a blank white screen.
May 11, 2013 | Polaroid Hiteker Msav2611 Msav2611-k3 26"...
Tv not responding to remote
the remote may have dropped and there are 2 possibilities of fault.
1-acrystal which gives accurate frequecy was broken
2- the infrared sender led was burned or the printed cicuit connection for this IR led is broken
Jan 28, 2013 | Sonic Impact Technologies Sonic Impact...
View Sonic TV wont power on
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | ViewSonic N4060w 40 in. LCD TV
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
I need the code to use a universal remote for a Soniq QV420PH 42" tv
Hello
Three digit univeral remote code for Sonic TV is: 014
Four digit universal remote code for Sonic TV is: 0014.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
OK.
Jun 28, 2011 | Televison & Video
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Remote
Remotes for this model are No Longer Available. A custom made remote may be available at www.NLAremotes.com.
Oct 02, 2008 | Supersonic SC-999TDVD 13 in. TV/DVD Combo
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
