Question about KL Industries Sun Dolphin Sun Slider Pedal Boat 6114
What engine would you recommend for my 5-person Sun Dolphin Sun Slider Pedal Boat?
Minnekota power drive 55bl. stuck at high speed. The foot pedal could turn the motor on and off, left and right, but when use slider to control speed it doesn't seem to have any contact.
If you can get inside the rheostat and move the wiper arm to properly wipe across the resistance then................
But often there is no getting inside and the only thing you can do is to replace the rheostat itself.
Aug 31, 2015 | Boating
Boat propeller
What do you mean it's too short,explain
Aug 16, 2014 | Dolphin Sun Pro 120 Fishing Boat Bass...
1986 Johnson vro70 will run on muffs in my driveway but wont start at the lake?
Possible probelm between the seat and the steering wheel.
Just kidding.... funny though!
Need more information to help. Something probably came loose on the way to the ramp, the kill switch in engaged, or the shift is not in neutral.
Jul 31, 2013 | Dolphin Sun Pro 120 Fishing Boat Bass...
Dolphin bluetooth won't pair with iPhone 5
Clear the memory on the Dolphin by pressing the CALL and END buttons together for about 5 seconds. The 'clearing memory' message will be heard followed by "Memory cleared".
now pair your phone using 0000 or 1234 as the pass key.
Feb 25, 2013 | Dolphin Radio Communications
Can hear water in the hull; is there a quick drain and where is the most likely area it is leaking from, is there a kit? model H27.
in the nose of the boat right next to the handle theres a funny looking switch if you stand the boat on its nose and flip the switch it will let the water out.
But...in my personal opinion it keeps the hull a little lower to the water and the paddles deeper...
Feb 04, 2010 | RTO Pelican Monaco Pedal Boat
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
KL Industries Sun Dolphin Sun Slider Pedal Boat 6114 Logo
113 people viewed this question
Top KL Industries Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KL Industries Boating Expert? Answer questions, earn points and help others
