Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Drive full?? Ive bought D2 1tetrabyte,and im using mac g4,the problem i have right now is,i just used 200GB,and suppose 2 be,there are 700GB remaining rite?but when i check remaining space,it says here there's only 100GB remaining.ive checked everythng,from trash,folders,sub folders,reconnect and also the other thing is,it says there i got bout 70 files there..but when i calculated all back.files by files..23 of them are missing..its like the files are not there..can somebody help me with this..my dateline is near.pleaseee..
  • 44 Answers
I think this article may explain it. You may need to break up your external drive in to 200 GB chunks so you can see all of the space: http://docs.info.apple.com/article.html?artnum=86178
Posted on Sep 15, 2007
SOURCE:
How to put my mac book pro back to factory settings without reinistall disc
Use Disk Utility to erase the hard drive. ... The process of resetting a Mac or MacBook tofactory settings gets rid of all your data ... This cloned drive can be re-cloned back to the main drive if you decide to restore your Mac, or it can be used to ... This means it will no longer be linked to your iTunes account. MacBook supportnumber 1 800 726 0294 Apple Technical Help
Sep 13, 2017 | Apple MacBook Pro 13
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Reset_To_Factory_Setting on mac ibook g4
Justin I suppose the easiest way to do this would be to insert your system disk into your ibook boot it up holding down the c key on your keyboard and then instal a fresh system. Use the erase and instal option as this will erase your hard drive. Any other queries get back to me, hope this helps. By the way a step by step way of doing this can be found at http://macs.about.com/od/leopard105/ss/installleopard.htm although it's leopard it should be similar across system.
Oct 31, 2011 | Apple iBook G4 Mac Notebook
My G4 see the drive but it thinks it is a 120 GB drive when it is really a 500 GB drive. How do I get the G4 to recognize the 500 GB drive as a 500 GB drive and not as a 120 GB drive? Jim
The drive may not be formatted to correctly to work with a Mac as most are pre-formatted for PC use.
Use the Disc Utility on your Mac application to format your drive as Mac OS Extended.
Use the Zero out data option for best results, this may take an hour or two. It's in he Erase section.
May 27, 2011 | Apple Power Mac G4 Desktop
Uploading video from sc-d353 camera to Mac
Final Cut may not sync with the Camcorder. I assume you're running firewire into the g4. Try capture as an analog device.
Jul 26, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
My mac G4 not recognize my 500GB external FantomDrive. HD light is on but Mac can't see it!
If you bought it from a friend, then ask them to reformat it for you as a FAT32 partition. Mac can not see NTFS, which most Windows users use since you get more space on the drive.
If it is brand new and your G4 isn't recognizing it, then I would return it for a new one. I don't trust things that aren't working out of the box, especially when they charge so much for things.
Dec 16, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
I've just bought one of these for a Mac G4 running
You need to locate a piece of software called Patchburn - but I think that might be difficult now.
This particular vintage mac only worked with the drive that was in it. in order to use a different drive you had to patch the system so that the new drive would be recognised as a burner - that said, it should just work as a player/CD-ROM.
The later Macs didn't have this problem and you could stick a drive in and it would be recognised straight away as a burner. I recently put a LG drive (with lightscribe) into a G5 mac and it worked straight away as a burner/player but I did have to install the lightscribe software.
Oct 13, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Problem loading Photoshop Elements 6 to Mac from CD-Rom?
You probably received a faulty disk, just return it to Amazon and ask for a a replacement.
Regards -- Joe
Feb 06, 2009 | Adobe Photoshop Elements 6 for Macintosh...
G4 Power Mac not seeing the external drive
Yup, I'm afraid the only known solution is to return to an earlier version of the opertating system. I suspect that if you recall - the item disappeared after a security update. Shame eh! Robin
Sep 07, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
125 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
