Question about Car Audio & Video
Hello I have two audiobahn alum 12n speakers. I also have two amps a jl audio 250/1 and planet audio TQ1601D 1600 WAT AMP which amp should I use
5 Suggested Answers
Jexx
  • 148 Answers
SOURCE: My JL audio 1000/1 amp does not work
Best bet is to send it back to JL, they do not sell the PCB with all of the components loaded on it. Most likely the transistors in the power supply have fried. Open it up and see if you can find any physical damage. Google the part numbers of the bad parts, and you should be able to fix it relatively easily. www.digikey.com is a great place for parts. Read this for more testing procedure: http://www.bcae1.com/ampfail.htm The whole site is wonderful, really.
Posted on Jul 16, 2006
  • 7 Answers
SOURCE: audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Posted on Dec 21, 2007
  • 113 Answers
SOURCE: jl audio 1000/1 amp
disconnect power and remote for 15min
Posted on Sep 08, 2008
etirbynnor
  • 655 Answers
SOURCE: 550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Posted on Mar 28, 2009
I have a Jl Audio 250/1 mono block amp and the thermal light keeps coming on what could be causing this?
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Mar 04, 2011 | Jl Audio 250/1 Car Audio Amplifier
I have 2 4 ohm 12" audiobahn jw1251j and a 1500 watt mono planet audio amp. what ohm do i wire the subs to the amp
depends how low your amps impedance goes down, if it can handle 2 ohm then you have to connect your speakers parallel to it (both speaker plus to amps plus and both speakers minus to amps minus) this will result in 2ohm speakers. if your amp does 4 ohm then use either one speaker for 4 ohm or two speakers in serial connection (in row) but you will have then 8 ohms.
Feb 28, 2011 | Car Audio & Video
My amp wont power down as soon as you connect the ground and power it comes on the car isnt on
make sure your remote wire is functioning and powering up and down with the radio that could be what the problem is.
Oct 13, 2010 | Planet Audio TQ1601D Car Amp
Why does My AMp turn off
  You need to use 4 guage or larger wiring with this amp. Also you need to make sure the power wire and ground wire are the same guage.(thickness)
   The ground wire needs to be as short as possible from the amp to the metal of the car.
  Make sure you are using a 14 guage or larger speaker wire form the amp to the speakers.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Whats better
i would go with rockford cause they under rate alot of there stuff so it is actually better than what they say it is and audiobahn over rates there stuff so its wors than thay say w3v2 12's can be purchased at pro car sterio in roseburg oregon you can get them online @ jl audio.com for about $125.00 for the 12's and $110.00 for for 10's
Dec 02, 2008 | Jl Audio 12W3 Car Subwoofer
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Jl sub not powering on
ok try your sub on another amp is first find out if that works or not if it works then there's a good chance you amp is knackered
Feb 22, 2007 | Jl Audio 10W3v2 Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
