Excel files fail to spool in my Deskjet F4100. However, the same excel file gets printed (from my same PC) using other printers like Laserjet 1020
SOURCE: HP 1020 printing problems
I agree with pastorm. In Excel go to View and select Page Break Preview. Once you are in this view, move the blue line on the right to the left to keep the unwanted area from printing.
SOURCE: my deskjet 2460 canĀ“t print excel files
I need a installer driver of my printer HP Deskjet D2460, kindly please help me. Thanks
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
SOURCE: HP4000n (Not printing borders on Excel and Word)
this is because your document content is out of range for your printer settings
clik on file - page setup and adjust your document properties from there
SOURCE: Problem printing Excel files with HP Deskjet 2640
لو سمحتم ارسلوا لي ملف تعريف الطابعة HP Deskjet 2640
