Copeland compressor technical support - Heating & Cooling
2 Suggested Answers
refritech08
  • 149 Answers
SOURCE: Copeland A/C compressor Phase monator
Are you good with wiring?? you can use replacement monitors is there a supply house in your area? just purchase replacement ones they have instructions on wiring them up. if you need any more help with the units just email me at hvac.tech7872pr@gmail.com
Posted on May 05, 2008
Is my copland compressure cr32x6 pfv220 a scroll or hermatic type compressure
Reciprocating http://www.hvacpartsoutlet.com/Copeland-Reciprocating-Compressors-R22/
Oct 24, 2016 | Heating & Cooling
Copeland KAN 2- 0050-1AA Serial ct 91J 1067A
Is there a question here? You've identified a Copeland semi-hermetic 1/2 hp compressor that runs on 115 volts and was made in November of 1991
Jun 07, 2011 | Freezers
What year is my Goodman Copeland Model # CR28K7-PFV-230 Serial # 07H93251H
The year of this Copeland scroll compressor is a 1993 model. 208-230 volt single phase.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Goodman Heating & Cooling
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Need help in AC compressor replacement. The existing compressor number is C-SB351H6B and its a SANYO.? What is the BTU rating for this compressor and what would be the replacement with a copeland scroll...
This compressor has a rating of 56700 BTU at 45 deg. F Evap and 130 deg. F Cond.
Your supplier will match a copeland scroll using this rating
Fuji
Aug 03, 2009 | Heating & Cooling
Copleland scroll compressor failure
I have scroll chiller contains scroll compressor tandom circuit. One of the compressor failure from it due to unbalance of the winding. Previously compressor thermistor opens two to three times. Also one phase open in contactor of the compressor. Can you guide me regarding the reason of compressor failure and what is the next step for the replacement of compressor. Also give guide line for the points take care.
Nov 02, 2008 | Goodman Heating & Cooling
Copeland Comfort Alert diagnostics . code #8 welded contactor. new install trying to startup. ive seen this once before but cant remember what i did to fix. can you help.
All this means is that the Copeland monitor is sensing amp draw on the compressor but it is not detecting a Y signal calling for the compressor to run. If there is no problem with the contactor and equipment is running fine, check for the jumper wire that carries the Y signal over to the compressor monitor.
Jun 25, 2008 | Amana Heating & Cooling
May 04, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
