Question about Mitsubishi LT-52148 52-Inch 1080p LCD HDTV
Replace power supply for mitsubishi LT-52148
I need to replace the defective power supply part 934C292002 in my Mitsubishi LT-52148 TV. How hard is it to replace it by myself. Where can I get a step by step instruction to open the TV and replace the part?
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
See this instruction. God bless you
    • 1
      Unplug the monitor power cable. You should never attempt to disassemble an electronic component without first detaching it from its direct power source.
    • 2
      Remove the screws from the back of the monitor and along the edge of the screen. Depending on manufacturer and model, LCD monitors will have screws located on different parts of the monitor's body. Once the screws are off, use a flat-tipped tool, such as a knife or a screwdriver, to pry the monitor open by dislodging the two halves; be careful not to tear wires connecting the two halves.
    • Sponsored Links
    • 3
      Locate the power supply unit and take its metal casing off. Once again, different models of LCD monitors will have the unit placed in different locations. With the casing undone, unplug cables running from the power supply to other internal components. Mark the cables that you unplug from the power supply--you will have to plug them back in to the new unit.
    • 4
      Dislodge the power supply from its dock. In some monitors you might have to undo screws that hold the power supply unit in place. Remember the orientation of the unit as it was placed, because you will have to insert the new unit in exactly the same way.
    • 5
      Insert the new power supply into the dock and screw it in place. If you do not have a new power supply, read the label on the existing one to order a new one from the manufacturer or from a third-party supplier. Obtain a power supply unit that is compatible with your LCD monitor; never try to use a generic spare. After installing the new unit, plug in the cables exactly as they were in the old unit.
    • 6
      Put the power supply casing back on and reassemble the LCD monitor frame. Gently clasp the two halves of the monitor shut, making sure you have reattached all cables that you unplugged to take the monitor apart. Close the casing, tucking away all cables neatly so they do not get in the way of the monitor casing.
    • 7
      Put all the screws back on. Once done, you should have no leftover pieces (screws or cables).
Read more: http://www.ehow.com/how_6165539_replace-lcd-monitor-power-supply.html#ixzz2ZJV8TbYP
Posted on Jul 17, 2013
2 Suggested Answers
  • 8457 Answers
SOURCE: Mitsubishi LT-52148 lcd tv turns on for 2 seconds
The lamp LED indication flashes?When was the lamp replaced?The lamp has not been replaced 1 1/2 or 2 years.The lamp life is over.Require a new lamp.
Posted on Sep 01, 2010
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
Can a soundbar an sub woofer be hook to Lt 52133, 07 model. if so how and what product #.
Yes! Use the digital audio output from the Mitsubishi TV to the soundbar! You need a digital audio cable that usually comes with the soundbar!
Dec 30, 2014 | Mitsubishi LT-52148 52 in. LCD HDTV
Mitsubishi LT-46131 powers off on its own
It could either be a faulty power outlet that you are plugged into or the power supply is overheating and triggering the circuit breaker ( reset button )
Dec 02, 2013 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
Blue vertical stripe on the right of the screen
The panel is bad. Contact mitsubishi . Some of these units have 5 year warr on the screen.
Sep 01, 2011 | Mitsubishi LT-52148 52 in. LCD HDTV
Mitsubishi LT-52148 lcd tv turns on for 2 seconds with sound and shuts off.Tried resetting.What could be the problem?
Sep 01, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
I have a LT-52148 that turns on with sound for 2 seconds and shuts off.I tried to reset several times without success.Any idea what the problem could be? ...
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop. This will help. Thanks
Aug 30, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
I need a power cord for a mitsubishi LT-2220. Were can I find one?
That ac adapter seems hard to find from secondary sources, but you might try from Mitsubishi. Their website is: www.mitsubishi-tv.com . I would reference to the parts department. Their parts department also has a toll free number: (800)553-7278
Hope this helps
Jul 24, 2010 | Mitsubishi LT-2220 22 in. LCD Television
My Mitsubishi LT 3050 now when turned on today has no picture.
hi..it seams that your tv is high heated or it is needed to change some of the transistors... just replacing ur transistors with the help of some tv tecnician would solve ur problem...
thank u rate me!!
Feb 10, 2009 | Mitsubishi LT-3050 30 in. HDTV LCD...
Mitsubishi LT-52148 52-Inch 1080p LCD HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
