Maytag washer f74 code problem - Washing Machines
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
F74 what does this mean
.. error code f74 Water pressure switch is staying closed.
Apr 10, 2016 | Miele DG155-1 Steam Oven Single
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
Sep 30, 2014 | Maytag MAH6500 Neptune Front Loading...
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My whirlpool duet washer displays an "F 74" error code. We had a power outage, the washer is plugged into a surge protector. I called whirlpool last night - they had me unplug for around 10 minutes, plug...
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Oct 09, 2009 | Washing Machines
Whirlpool duet
F74--UI Eeprom failure
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2008 | Whirlpool AWM9000 Front Load Washer
Panasonic SC-PM08 shuts down error F74
Very nice unit this one but Im not able to help you with the code but sounds like its shutting down because of an overload . Contact Panasonic but you may be surprised on how bad panasonic treats there customers as it say that Panasonic answers very few of there BBB complaints???good luck
Apr 07, 2006 | Panasonic SC-PM08 Shelf System
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
