Question about Microwave Ovens
Demo mode on..how do I get it off
After opening the door, buttom was stock. we heared a bleap sound. afther that the demo mode was on. how do we get it off?
  • 17,000 Answers
What is the make and model?
Posted on Jul 22, 2013
My oven AZKM755 is locked in demo mode, how do I get it off demo pls.
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
If unable to access the DEMO setting, contact Whirlpool at: https://www.whirlpool.com/services/contact-us.html
Dec 23, 2017 | In Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
My oven turned in mode demo. Do you know how to turn it off?
Perhaps if you gave the manufactures name and model # it would be easier to give the correct answer. Perhaps reading to book that came with unit would provide the answer.. Perhaps.. unplugging unit wait a bit then plug it in again will reset the unit... Lots of perhaps.. never heard of a demo mode, what would be the point of that with a microwave... sounds like something is broken such as the door switch or a Ckt. Board fried or the megatron died...
Nov 25, 2015 | In Microwave Ovens
How to switch off Demo Mode in JT 379 Micro? Please, help!
Open the door and then push the start button for 5 seconds till you hear a beep.
Jan 29, 2012 | Whirlpool Microwave Ovens
Model KCMS1555RSS appears to be in demo mode. How do you turn that off?
Here is what I found. You can click HERE for the owners manual online, but here is the skinny
To Turn On/Off Demo Mode: Touch and hold TIMER for 5 seconds until 1 tone sounds, and "DEMO ON" appears in the display. Repeat to turn off Demo Mode
Happy to help anytime, please rate service :)
Joe
Sep 01, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Dimension4 micoweave oven door will not open. I heard a sound like piece of plastic dorping and oven door stayed closed after I pushed on the open buttom
door asembly has collapsed as you might have guessed. Bit of a job to get it open without removing the whole outside coverings, even then it wont be easy. You will have to replace the assembly anyway, and it might be easier to get it serviced at a specialist shop. Labor cists are the biggest outlay here as the assembly lock is about $60 if i recall correctly
Aug 14, 2009 | Microwave Ovens
How would i know if door switch it is not working on my microwave
Use a multimeter and set it to ohms or continuity (the multimeter could have an audible symbol and when you touch both leads should make an audible sound, most of them work this way), if it's a normally open switch you should have continuity (a sound from the meter or a zero or zeros) when the door is closed only and no sound from the meter when the door is open. If the switch it's normally closed you should hear a sound from the meter when the door is open and no sound when the door is closed. If you have a sound from the meter with the leads connected at each side of the switch regardles if the door is open or closed your door switch is bad or if you don't hear a sound from the meter regardles if the door is open or closed the door switch is bad.
Apr 04, 2009 | General Electric Microwave Oven
We had a power blackout now my panasonic genius microwave is stuck on demo mode. How do I get it off demo mode?Is it fried or fixable?
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Mar 07, 2009 | Microwave Ovens
Microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
IT CONTINUES TO RUN AFTER DOOR IS OPENED
This is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-P994SF Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
