Question about Clarke Power Products Drills
Wiring diagram 3hp single phase four pole - Clarke Power Products Drills
bigg t
  • 640 Answers
SOURCE: converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
Posted on May 14, 2009
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
  • 6 Answers
SOURCE: converting 3 phase compressor to single phase
Start w/ a single phase motor. Or maybe your question is just confuseing me.
Posted on Sep 12, 2009
vahai2004har
SOURCE: looking for a hobart amx dishwasher wiring diagram
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Posted on Jan 15, 2012
SOURCE: Wiring diagram for single phase two pole 2.5 HP induction motor.
There are two windig in the motor starting and running the two winding end are joint and take nutral and other two wire connect to capacitor paralel and take one lead starting winding and give supply
Posted on Sep 09, 2013
Is this considered a single throw switch or a tripple throw switch and what's the difference
We cannot see the product you are asking about
Example single throw switch is household light switch ..., flip the switch either direction and load turns on-off.
Example double pole switch is 240 volt double breaker... flip the breaker and two wires turn on-off.
Example triple pole switch is any 3 phase contactor or 3 phase timer ... flip the switch and three wires turn on-off
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/3-Pole-contactors.html
Gene
Water Heater Timers Save Money
Apr 27, 2015 | Electrical Supplies
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
I have 110 volts n each leg but not 220 across both why??
In a traditional North American residential electrical panel (120/240 volt, single phase), installing a single width or single pole circuit breaker, you would expect to read 120 volts from the breaker terminal screw to either ground or neutral. A double width or double pole breaker would provide 120 volts from either of the breaker terminal screws to ground or neutral AND it will provide 240 volts BETWEEN the TWO breaker terminals.
A single-width circuit breaker case that contains two handles is NOT a two pole circuit breaker (these are called "tandem" or "1/2 size" breakers). This is because a single width breaker engages only one "line" in the panel. A double width breaker will engage 2 "lines" as a triple width breaker would engage 3 "lines" of a 3 phase panel. A single wide breaker can not physically engage more than 1 "line" so it will never be able to pass 240 volts.
You must install a double width / double pole breaker to safely supply a 240 volt circuit / device.
Mar 15, 2014 | GE 20 Amp 1 In Double Pole Circuit Breaker...
How to conect three phase 5 wire conection to 4 wire 380volt three phase from the machine
Identify each of the 5 wires with voltage testing.
Find which breaker serves the 3-wire, and which breaker serves the 2-wire.
--You might have a 3-pole 3-phase breaker (with 3 hot wires) plus a single-pole breaker (with 1 hot and 1 neutral) ... giving a line with 4 hot wires and 1 neutral.
--Or you might have a 3-pole 3-phase breaker (with 3 hot wires) plus double-pole breaker (with 2 Hots) ... giving a line with 5 hot wires and no neutral.
The 4 wires from machine are probably 3 Hots and a neutral, or 3 Hots and a ground.
You need to identify where the ground wire is. One of the 5 wires from breaker box might be a ground.
Copy following links:
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://www.electriciantalk.com/f5/
Gene
h
Sep 05, 2013 | Hardware & Accessories
NEED a wiring Diagram for a Dayton 3hp motor model # 5K967M is there anyone out there that can help me
you don't need a wiring diagram for 3ph. this motor is single phase. either 120 or 240v. you just need to fing out what power you will power it with and read the inside cover for the wiring box on the motor. given to you by an electrician w/35 yrs experience.
Mar 08, 2011 | Kitchen Ranges
I have a wood planer with a 3HP 220 single phase motor wired to 20amp circuit breaker in my house. I usually run the planer off a 12gauge extention wire about 30ft from the house plug. I would like to...
Look on the planer to see what the R.L.A. are, for example 16.0 amps. Set a box with 2- 20 amp fuses, or a double pole 20 amp breaker. Do not exceed the amperage of what the planer says on its data plate. If the R.L.A. is 10.0 to 19.3, use a 20 amp.
Sincerely,
Shastalaker7
Jan 20, 2011 | Inline 20 amp. In-Line Circuit Breaker
I am looking for a wiring diagram for a basic outdoor ac unit. I have run across a mess of wires disconnected inside a unit. Mainly looking for a diagram explaining what wires go where on a two pole...
See Page 7 of this Installation Manual of a basic condensing unit. There was no reference regarding the phase of the unit. This manual shows single and three phase. Hope this is very helpful to you. :-)
May 06, 2010 | Heating & Cooling
all you have to do is (a) open the connection box of the motor look for the two wires of the starting or running coil, inverse only one coil wire.(a) If there is no centrifugal switch in the rotor, try this it might help open the motor both end,change the direction of the shaft ,which i mean pulley side goes to fan side and fan side goes to pulley side and tighten all bolts.
Sep 11, 2009 | Air Tools & Compressors
Carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Dec 22, 2007 | Carrier 38CKC036 Air Conditioner
Drills Logo
64 people viewed this question
Top Clarke Power Products Drills Experts
Are you a Clarke Power Products Drill Expert? Answer questions, earn points and help others
