Question about Microwave Ovens
Demo mode wirlpool JT 378
Help!! the demo mode is on. How do i get it off?? the microwve doesn't work
2 Suggested Answers
SOURCE: How to switch off Demo Mode in JT 379 Micro? Please, help!
Open the door and then push the start button for 5 seconds till you hear a beep.
Posted on Mar 17, 2012
Quasar microwve superwave
I'd like to help, but i will want you to please explain your question better
Aug 28, 2012 | Amana Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
Jan 29, 2012 | Whirlpool Microwave Ovens
Stuck on demo mode. how do i get it back to working
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 24 of the manual for instructions on how to deactivate the DEMO MODE.
Basically, if your Panasonic microwave display shows DEMO MODE, then just press the CLOCK button on the control panel 3 times in a row.
The display should then go blank indicating that it has successfully returned to normal cooking mode and can be operated as usual.
A few models require you to push the CLOCK button 4 times to clear the DEMO mode, so try that as well if the above instructions do not work for you.
I truly hope that was helpful to you Monique.
Good luck and take care.
Joe.
Dec 04, 2011 | Panasonic NN-C994S Convection/Microwave...
The light inside goes on but the microwave doesn't
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
Demo mode on
The instructions to turn the demo mode OFF on the model you have listed, can be found on page 24 of the owner's manual. Press the CLOCK pad three times to clear. If you no longer have an owner's manual, you can download a FREE copy at managemylife.com. Here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/6952/PANASONIC-Countertop-Microwave-L0604142?brand_name_search=NN-C994S
I hope this helps you.
May 03, 2011 | Panasonic NN-C994S Convection/Microwave...
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
Stuck in Demo Mode
I will need a model and serial no to further assist you
Jun 19, 2008 | GE CVM2072SMSS Microwave Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
