Question about Garden
Husqvarna riding mower
Husqvarna LGT24k54 stops after 30 minutes of mowing sometimes a bit longer, it will start right up no problems but it will keep on turning off every 2-3 minutes after restarting it I have checked or replace the air filter, inline gas filter and cleaned the spark plugs, I bought it brand new 3 month ago and have taking it to the dealer twice but they can't fix the problem, have you any Idea what's causing this problem?
  • 2,239 Answers
The fuel tank breather is in the fuel filler cap, run the machine with the filler cap loose to allow air in, if the tractor runs ok, then replace with a new cap.
Posted on Jul 17, 2013
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
Posted on Jul 20, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
  • 1746 Answers
SOURCE: Recently bought a 2004 Husqvarna
Hi, I would check the pump out. Air maybe getting in pump. You should get a rebuild kit for pump.
Gasket(s).need to be replaced. cracked or ripped. Hope that works for you.
Posted on Jun 12, 2011
philwalker78
  • 608 Answers
SOURCE: Our Husqvarna YTH2148 mower has been in the shop twice and we can't figure out what's causing black, sooty fouling of the spark plugs.
Hi, change the engine oil. It has become contaminated with fuel. Also fit an inline fuel tap and turn it off whenever the mower is not in use. Basically the carby has leaked fuel into the engine oil, the engine then draws the fuel vapour from the oil through the crankcase vent into the carby creating the problem you have. Regards Phil.
Posted on Jun 04, 2012
  • 40 Answers
SOURCE: Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
Posted on May 13, 2013
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Husqvarna lgt24k54 keeps turning off
Interesting! Try seeing if it will run without the fuel tank cap on. There is normally a small hole to let air in as fuel is used, if this gets blocked the fuel will stop running from the tank. You probably won't be able to clean it well enough so a replacement cap shouldn't be too expensive.
Jul 17, 2013 | Husqvarna LGT24K54 54" 24HP Kawasaki Lawn...
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
HUSQVARNA RIDING MOWER BLADES STOPPED SPINNING
Your deck belt adjusted or maybe a spring or etc. come off.
May 13, 2012 | Husqvarna Garden
JUST PURCHASED A HUSQVARNA YTH2042XPT 2006 MODEL. AFER 30 MINUTES OF MOWING THE HYDROSTATIC DRIVE STARTED TO MAKE GRINDING NOISES AND IF KEPT DRIVING 10 MINUTES LATER THE MOWER LOST ALL POWER TO ITS...
Well if new I would take it back and if used I would be looking for another hydrostatic transmission.
These can be found on ebay, and there are some lawnmower recyling yards out there, you have to look for them. The price of a new transmission far exceeds the price of a used mower and is almost the price of a new mower.
Oct 18, 2010 | Husqvarna Garden
Mower keeps cutting off while trying to mow or ride with blades dis engaged. It will act like it is about to cut off a few times then it finally will. Doesn't matter the throttle position( low or high)....
This might be a stripped wire somewhere, maybe a wire going to a safety switch under the seat or on the cutting deck and it is earthing against the body from time to time.
Stephen.
Jul 03, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
