How to reset Error code 2618 in oce cs2436
Oce cs 2436 is showing a error code03130031 2618 i replaced new print head main pcb power supply unit carriage unit still the problem is same kindly advice
SOURCE: carriage error
Solution to get rid of error 1203 on printer 926 is
Disconnect and Reconnect the Printer Power Supply
  1. Unplug the power cord from the wall socket.
  2. Disconnect the power supply from the back of the printer.
  3. Wait 15 seconds.
    Reconnect the power supply to the back of the printer.
  4. Plug the power cord back into the wall socket.
Try a Known-Good Ink Cartridge in the Printer Replace each affected cartridge in the printer with a known-good cartridge and check to see if the problem is resolved.
This error comes up because the copper contact of the cartridge is not able to communicate with sensor of the printer.
Abhishek
Posted on Dec 20, 2007
taran_2005
  • 10515 Answers
SOURCE: my printer lexmark e352 shows an error code 84
The above error code refers to :-
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • 10 Answers
SOURCE: OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Posted on Jun 30, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: hi hp designjet t1100ps plotter showing
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Posted on Apr 02, 2011
nnoorrookk
SOURCE: xerox 3100 mfp error code (HSYNC)
xerox phaser 3100 mfp error HSYNC
What can i do to solve ?
Posted on Dec 11, 2012
Error 03130031-2618 in canon ipf 750
Error code 03130031-2618 is a voltage error. It could happens on these printers models: IPF6350, IPF6300, IPF6000, IPF8000, IPF8300, etc...
Solution 1:
  • Power off the printer.
  • Disconnect the power cable
  • Wait for 30 minutes.
  • Connect the power cable
  • Power on
Solution 2:
  • Check the power supply
Solution 3: The voltage of the print head is abnormal.
  • Replace the Printhead
Solution 4: Check for the cable continuity between the carriage relay PCB and the main controller PCB
  • Replace the cable.
    Replace the carriage relay PCB.
  • Replace the main controller PCB
Oct 26, 2017 | Canon Office Equipment & Supplies
In canon ipf 750 Error 03130031-2618
this is what i am finding out from other fixya site members so if this helps you out its them you need to thank...
Follow these steps :Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead -head relay PCB -Carriage relay PCB -Main controller PCB
Steps to be followed:
1. Replace the printhead. 2. Cable continuity check. if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable. 3. Replace the head relay PCB. 4. Cable continuity check. if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable. 5.Replace the carriage relay PCB. 6.Replace the main controller PCB...
In my knowledge the error indicates the voltage on the print head is abnormal. It is an hardware related issue.
Possible cases can the print head is faulty or the relays to the PCB may be faulty or the PCB itself.
We have to perform continuity checks between the relays and between relays and PCB. then we can confirm if the relay is faulty or the cables between them . If not print head would have failed and needs to be replaced...
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit
What causes error 031300312618?
Farid: According to http://www.copytechnet.com/forums/canon/56346-ipf8000-error-03130031-2618-a.html : this is "Print Head failure.
First try replacing the Print Heads and if the problem persist, re-seat all the cabling to the Relay PCB and the Carriage Unit PCB.
A loss or faulty connection to either one of the PCB's could cause the problem. In one case, the problem was related to both a faulty Flex Cable Assembly (QM3-2005-000) and the Carriage Assembly PCB (QM3-1995-020) for the IPF8000 and (QM3-3093-000) for the 8000S.
May 14, 2015 | Canon imagePROGRAF iPF8000 Printer
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
I have a canon IPF6300 large format printer and it is coming up with error code 03130031-2618
This code indicates a print head failure. First try replacing the Print Head, if however the problem persists things get substantially more complicated. Unless you are very techie it would be best to call a technician as further steps involve re-seating all the cabling to the Relay PCB and the Carriage Unit PCB. See more here.
Sep 17, 2012 | Canon imagePROGRAF iPF6300 Large Format...
Error 03130031-2618 restart does nothing
printhead error. Sometimes not an easy fix to troubleshoot. Might need a new head, new relay pcb or main controller. If the head does not fix then plan on spending more money. upwards of $1000 usd
Jun 19, 2012 | Canon imagePROGRAF iPF6300 Large Format...
Canon ipf750 error 03130031-2618
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Hardware error 03130031-2618
Follow these steps : Cause: The Voltage of the print head is abnormal.
May 15, 2011 | Canon imagePROGRAF iPF8000 Printer
Code error 41
Error 41
The head drive voltage has not been turned from Low to High within the specified time.
Check:
Carriage ASSY
Main PCB
Print head unit
Power supply PCB
Feb 27, 2009 | Brother MFC 3820CN All-In-One InkJet...
I have a machine error 36 of brother dcp-115c help me
Machine error 36
**Head/carriage unit travel error***
Try to find any obstacles on the travel path of the head/carriage unit. If you cannot find, next steps are:
- Replace the carriage PCB.
- Replace the head/carriage unit.
- Replace the CR encoder strip.
- Replace the carriage motor.
- Replace the main PCB.
- Replace the power supply PCB.
- Replace the maintenance unit.
Nov 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
434 people viewed this question
k24674
jasbo
jasbo
