Ms 7145 I've just got this computer from a garage sell and it powers on fans come on lights come on. But theres no display on the monitor at all. The monitor doesnt even boot on when you turn the computer on. Theres no graphics card. Its using the integrated g card ati ixp 200. Im outta options ive reset the bios ive looked the motherboard over n nothing looks burned. I need some help!!
    Brigadier General:
  • 3,400 Answers
William ,are the monitor okey,you maybe should try with a other.
did it came with a Os or.
Posted on Jul 17, 2013
joey64
  • 209 Answers
SOURCE: p4v8x-x bios dont boot
your problem is in video card, try to remove and clean the connectors (bronze color) with an eraser. then re-install, if the problem still occurs try to hear beep (warning sound). we have different sound for the installed hardwares such as the memory card, video card and the boot sound. if you have installed an expansion video card remove this and use your on board video card to determine if the video card you installed is defective. and if you are using the on board video card install a new video card
Posted on Oct 22, 2007
  • 33 Answers
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
map9966
  • 2351 Answers
SOURCE: Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
Posted on May 15, 2008
Nic61
  • 1073 Answers
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
  • 46 Answers
SOURCE: I bought ATI Radeon HD5450
It's possible you need to disable the motherboard's onboard video before you plug in the graphics card.
Posted on Feb 28, 2011
Icons wiggle
Your computer screen or monitor may have wiggling images when it is too close to electronic interference, such as a power supply, cell phone, non-shielded speakers, a fan or electric motor.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 10, 2014 | Acer Computers & Internet
Why is just the fan only running
Try another monitor.
Jul 02, 2014 | Gateway GT5670 Desktop PC
No display but the computer turns on.
could be an issue with the graphics controller or with the monitor. first, verify if the monitor is actually working. try it on another computer or video source. if it works, make sure that you have a working video cable and check to make sure the video input source (dvi, vga, rgb, hdmi.. etc) selected on your monitor is the correct one that you are using. if you have ruled out the monitor, video source and cables, you can then test if another monitor will work with the computer. if same thing happens, meaning nothing on display even the manufacturer or BIOS screen does not show up when you turn on the computer, it is most likely the video controller. you may either get the motherboard replaced or install an add-in video card if the integrated video controller only has one video connector.
Jul 17, 2013 | eMachines MS-7145 Motherboard 103777
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
NO SCREEN DISPLAY WHEN BOOTING ON MSI MOTHERBOARD
first see pulg or correctly put
Then remove the fan and insert properly after completing then start the computer if u face again same problem i think fan is goan
Jul 31, 2008 | Intel Motherboard
ASTVision 20P 21 in.CRT Conventional Monitor?
the power cord can be purchased anywhere as it is standard 3 wire block connector.
radio shack , computer store, goodwill, garage sells,
tv stores,
Feb 04, 2008 | ASTVision 20P 21 in.CRT Conventional...
No display
Your monitor's signal cable is loose.Tighten the screws of the cable....
Oct 12, 2007 | E-Machines T2615 PC Desktop
Computers & Internet Logo
David Payne
David Payne
