Question about SAMSUNG GT E2652
Can't make call from call-logs.
If i call from call-logs, it should produce Error "No Number". But the no is in contact, i got call from that no, and i can call from that no through contact only, but not from call-logs. This problem to all numbers, including new number also. How to solve it?
  • Yuvaraj Jul 17, 2013
    k thank you....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Format the phone
Posted on Jul 17, 2013
kareena
  • 75 Answers
SOURCE: samsung L760 mobile service person address and contact number
hey go on to google site type samsung dealers in chennai so u will be redirected to authorized dealers.
Posted on May 31, 2009
  • 157 Answers
SOURCE: Contacts Name or Number not appearing when they call
Maybe the conflict or Operator things !
I mean if you have same numbers in your sim card and phone memory at sametime phone can get conflict issues , because phone also got confused what to put on the screen !
F480 itself has an issue with colliding CALLER ID and NAME DISPLAY.As you know, name display shows up when you don't have the incoming call number. However, this device ignore CALLER ID and just show NAME DISPLAY...
SOLUTION:You need to call your operator and disable NAME DISPLAY ONLY.
Best Regards
Posted on Jun 24, 2009
  • 16 Answers
SOURCE: How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Posted on Aug 02, 2009
exclusivemik
  • 34 Answers
SOURCE: how to delete recent contacts from the text
PRESS THE DELETE BUTTON A FEW TIMES.
Posted on Aug 07, 2009
  • 5 Answers
SOURCE: Remove number from reject list on a Samsung S7350
this should work,go into settings,then call settings,then all calls then auto reject and then click on your reject list,i hope this helps.
Posted on Jun 17, 2010
Testimonial: "Not quite how the menu is in the Samsung S7350,I have shown the steps below but I would have had no idea without your help and the fix worked so thank you very much the steps are Settings-Application settings-call-all calls then select off. Thank you again I have been trying to sort this for two months and have rang my phone supplier 4 times but they didnt help at all "
How do I Fix Windows Update Error 0x800F081F?
.NET Framework 3.5 installation error: 0x800F0906, 0x800F081F, 0x800F0907 Error code 0x800F0906
Error code 0x800F081F
Error code 0x800F0907 Resolution for Windows 10 0" style="box-sizing: border-box; outline: none;"> Error code 0x800F0906, 0x800F081F, or 0x800F0907
Error code 0x800F0922 More Information 0" style="box-sizing: border-box; outline: none;"> These errors may occur when you use an installation wizard, the Deployment Image Servicing and Management (DISM) tool, or Windows PowerShell commands to enable the .NET Framework 3.5.
In Windows 10, Windows 8.1, Windows 8, Windows Server 2012 R2, and Windows Server 2012, the .Net Framework 3.5 is a Feature on Demand. The metadata for Features on Demand is included. However, the binaries and other files associated with the feature are not included. When you enable a feature, Windows tries to contact Windows Update to download the missing information to install the feature. The network configuration and how computers are configured to install updates in the environment can affect this process. Therefore, you may encounter errors when you first install these features.
Error messages that are associated with these error codes
Error code Error messages 0x800F0906 The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Windows couldn't complete the requested changes.
Windows couldn't connect to the Internet to download necessary files. Make sure that you're connected to the Internet, and click "Retry" to try again.
Installation of one or more roles, role services, or features failed.
The source files could not be found. Try installing the roles, role services, or features again in a new Add Roles and Features Wizard session, and on the Confirmation page of the wizard, click "Specify an alternate source path" to specify a valid location of the source files that are required for the installation. The location must be accessible by the computer account of the destination server.
0x800F0906 - CBS_E_DOWNLOAD_FAILURE
Error code: 0x800F0906
Error: 0x800f0906 0x800F081F The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
0x800F081F - CBS_E_SOURCE_MISSING
Error code: 0x800F081F
Error: 0x800F081F 0x800F0907 DISM failed. No operation was performed.
For more information, review the log file.
Because of network policy settings, Windows couldn't connect to the Internet to download files that are required to complete the requested changes. Contact your network administrator for more information.
0x800F0907 - CBS_E_GROUPPOLICY_DISALLOWED
Error code: 0x800F0907
Error: 0x800F0907
How to download the .NET Framework 3.5 outside of the Windows Update requirement
The .NET Framework 3.5 is available for customers with Volume Licensing or MSDN Subscription, as Feature on Demand Media is available.
Error codes are not listed when you install .NET Framework 3.5
When you install .NET Framework 3.5, you may encounter other error codes that are not listed in this KB, for more information, go to the following articles:
Dec 27, 2017 | Computers & Internet
Tip
Gmail Customer service solve problems of gmail account error
so many error comes in our Gmail account such your Gmail account not working
Google calendar embed only works when *not* logged in??
Page cannot be displayed when logging into google account
Google contacts do not display in Internet Explorer
Cannot access GMail, will not load. Page Cannot be displayed. Gmail Customer Service support can have ability to solve any problems of your Gmail account http://www.99techsolutions.com/gmail-technical-support.html
Gmail Customer Service Support 1 888 361 3731 Phone Number USA
on Jun 09, 2016 | gmail.com
I can't log on to my Facebook acct. I keep getting error 101.
unfortunately, you have to log into your account in order to contact support. i did, however, find this phone number for you for the facebook headquarters "1-650-543-4800". try contacting them that way.
i am always having problems logging into my facebook account. that is why i ended up with 3 or 4 accounts. i'd get fed up and just open a new one.
Jan 22, 2015 | Facebook Computers & Internet
I have been locked from Movie Star Planet, This is a public computer, many children have this game, they are the ones who showed this game to me, but every time I try to log on it says "computer locked."...
received lock number why
I received a lock number - why? Today at 17:51 Did you get a message saying that your access to the game has been blocked?
If so, our moderators may have found inappropriate activities on the IP address and decided to block it.
Users playing from your IP may have broken one or several rules.
Please remember to always play by the rules. You can read the rules here.
Please contact Support if you are sure this is an error.
Please remember to send along:
  • Your username and other accounts you recently logged in from
  • Lock number (the number you see when you try to log in)
  • A brief description of why you believe this lock is a mistake
If you need further assistance you can contact us here.
Use link below to contact them.
https://moviestarplanet.zendesk.com/hc/en-us/requests/new
Jan 31, 2018 | Optics
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
Nov 07, 2011 | Texas Instruments TI-30XA Calculator
Need new cylinder piston 35cc where to bye in south africa
You provide no model or I could probably get a part number here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I searched for Husqvarna South Africa and got this:
http://www.husqvarna.co.za/node2418.aspx
There is contact information, Please contact them they may have a list of dealers in your area. HTH
Lou
Feb 17, 2010 | Husqvarna Chain Saw 20" Bar
I have a skype account and can log in and check it how ever i can not log on to skpe
HI
You can first watch the following video if that does not help then contact skype technical support at
https://support.skype.com/category/TECH/Good Luck :-)
Dec 06, 2008 | Computers & Internet
I can't open my mail
I think you have to contact Yahoo to solve that problem, when you are logged in on yuor mail everything you do is happaning on yahoos server. So to solve this problem i think the people on Yahho is the ones to ask.
Good Luck!
Nov 20, 2008 | PC Chips (M925G) Motherboard
Sms messaging send to recent log
just text a few different people until the contact is no longer a "recent" conacts, i thinks its like the last so many contacts in the list, i'd check mine but my screens just broke
if your rich just get a new phone =]
Aug 23, 2008 | Samsung Ultra Smart F700
SAMSUNG GT E2652 Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
