Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
No display when i boot up
I just purchased my motherboard along /w video card, ram, optical and HD. Now that iv put everything together and have tried clearing CMOS using the recomended method in the troubleshooting section of www.asus.com. Still it continues to not work. So please someone help! Eric
I have had the same prob. with m2n-e Personally I brought my board into the local computer tech and asked him to test the board what he found out was that there was a cooling unit missing on the board wich cuased the board to overheat now whats this have to do with getting no video? simple it was the vga heat sink that my board was missing that cuased it not to work. I suggest you do what I did take the board in get it tested -
Posted on Sep 30, 2007
    Problem Solver:
  • 11 Answers
Can you tell me , Whats the changes you made in CMOS , while assembling the Pc
Posted on Aug 28, 2007
Computer will not boot up. Press power button to turn on, fans whirl up to full speed, no power/hd lights, no screen display.
This sounds like a motherboard issue, but first swap out the ram one at a time, next remove the hard drive, if no change remove the video graphics card, "if detachable" disconnect any hardware that may load down the motherboard including the dvd driver, if after everything still no change the motherboard will need to be replaced.
May 15, 2011 | Acer Computers & Internet
Sir i have msi n1996 mb.now no display in this mb what to do
The monitor could be faulty, try connecting a different monitor to see if you get a Windows image.
Next check the BIOS setting, if the video card is built-in on the motherboard, check the video settings.
Next the on-board video may have a video RAM problem, re-seat the RAM modules, the video card used part of the RAM memory (ie. shared memory).
Next if the video card is faulty, get or borrow a AGP video card and insert it into the AGP slot on the motherboard and connect your monitor to this video card then boot up the computer.
Each of these steps should identify and fix your video problem.
If you need further assistance, please leave me a comment together with any error messages.
Nov 11, 2010 | MSI PM8M-V Motherboard
I HAVE A DYNEX COMPUTER WITH A SYNTAX P4S865PE MOTHERBOARD, WIN XP PRO, MOTHERBOARD DRIVER DISC. new format and install, with no programs installed, 320sata hd, occasionally locking up, long time to boot...
You have to install all the mobo drivers first.
Ensure the CMOS is set to boot off HDD first.
If still a problem will most likely be faulty mobo.
Apr 21, 2010 | Computers & Internet
Hi, i just put together 2 ms7380 motherboards, pentium d 945 3.4 ghz 680 watt antec psu galaxy 9500 series video card WD caviar 500gb HD and have tried several 1 and 2 GB ram ddr2 everything turns on and...
Make sure power is connected to video card, Check standoffs, make sure no extras shorting mobo, Make sure video card is plugged in slot properly. Post mobo - cpu - ram - video card out of case. if all ok then mount with proper standoffs.
Nov 20, 2009 | Intel Motherboard
I recently perchased a motherboard and power supply unit, ram, video card, hardrive and cd rom, put everything together as directed but the only thing that come on is the led on the motherboard, what am i...
Check your connection again. Its seating should be good or did you happen to touch its edge connector (Ram, video, PCI card)? Most likely its Ram card is making it not to boot.
Pls post a comment, tnx
Apr 06, 2009 | ASUS Computers & Internet
Memory Issues with P5GL - MX
Some motherboards require that you install the memory in matched pairs. That could explain why they won't work together.
When you put the 1 GB in alone, what slot did you put it in?
I would suggest the blue A1 slot (closest to the CPU).
It may be that you have a bad memory module.
You could try the Windows Memory Diagnostic:
http://oca.microsoft.com/en/windiag.asp
You may also be interested in the motherboard's manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GL-MX/e2222_p5gl-mx.pdf
Feb 06, 2009 | ASUS P5GL-MX Motherboard
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
