Question about eMachines eM250-1915 Netbook
Emachine e267
Need new hard drive
2 Suggested Answers
danmats
  • 195 Answers
SOURCE: after emachine recovery disk run on new hard drive
that shows that it is not compatable with the settings of the PC.
Posted on Oct 06, 2009
HP PAVILION ZV5000 WONT BOOT UP HAS POWER ON LIGHTS AND NOTHING PLEASE HELP!
I had this same problem with my Emachines W3609 PC, it had the power on lights and nothing else. Try making sure that the hard drive and everything is connected properly inside. If the hard drive or RAM isn't connected it won't turn on. If that doesn't solve your problem than you might just need to get a new hard drive and re-install which ever Windows OS you want. Should work than.
Oct 08, 2013 | E-Machines eMachines Desktop PC
Changed hard drive on emachine e725 now says no bootable device insert boot disk. dont have boot disk
You will need to install the operating system on the new hard drive for it to boot.Also you need to set you're boot order in the bios to CD then the HARD DRIVE.Get the operating system set the bios boot order then install it.
Mar 28, 2013 | eMachines eM250-1915 Netbook
Error message "restore failed 0x00000070"
Step 1:
Which operating system ?
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings. Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard, mouse or monitor. Click the Windows "Start" menu and choose "All Programs." Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab. Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default." Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process. Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Mar 10, 2013 | Computers & Internet
How do I replace the hard drive on my emachines PC/
Power down the eMachines computer and unplug it from the power outlet. Remove the left side panel from the computer case by removing the two screws or thumbscrews in the back and sliding the panel toward the back of the computer. Should the panel not move, check to make sure that there isn't a latch or switch on the rear of the computer case that needs to be slid downward in order to remove the panel. Not all cases will have this feature. Locate the hard drive; it should be in a 3 1/2-inch drive bay located beneath the computer's CD and DVD drives. If your computer has a floppy disc drive, the hard drive will most likely be located in a bay beneath it. Check the position of the floppy drive to make sure that you know which 3 1/2-inch drive it is. You should notice two cables plugging into the back of the hard drive; one of these is the power cable that comes from the power supply, and the other is a data cable that is connected to the computer's motherboard. Unplug the power and data cables from the rear of the hard drive, leaving nothing else plugged in to it. Remove the screws that hold it into its mounting bay, setting them aside until you need them for the new hard drive. Slide the old hard drive out of the mounting bay, being careful not to drop it or hit it against any of the motherboard's components. Set the drive aside and pick up your new hard drive, then slide the new drive into the same bay that you just took the old drive out of. Line the small holes in the side of the drive up with the holes in the mounting bay. Secure the new drive by screwing in the screws that you had previously removed, then plug in the power and data cables that you had unplugged from the previous drive. The cables will only plug in when oriented correctly, so you won't have to worry about accidentally plugging them in wrong. Once the cables have been plugged in you can put the side panel back onto the case and plug your eMachines computer in once again. Hope this helps. http://www.youtube.com/watch?v=yQToRwe74P8
Jan 07, 2013 | E-Machines eMachines Desktop PC
Format WD laptop hard drive in Emachine laptop
Normally when u restore, formatting is being done at a certain step. Therefore no need to worry as the OS is included in the recovery. However if it's exactly how u r stating, therefore buy an external 2.5" HDD casing,insert ur HDD in it, plug it to the USB of any computer or laptop & get it formatted.
Feb 07, 2010 | E-Machines eMachines Desktop PC
Laptop wont boot up
Stay away from Emachines in the future. Pay another $100 and get a real computer.
1. check that nothing is in the CD-Rom drive and restart the computer.
2.Shut down the computer. Unplug the AC power. Remove the battery pack. Wait 2 minutes or until machine cools.
try powering on comp on battery alone, then try with AC power alone.
Dec 26, 2009 | eMachines eMD620-5133 Notebook
After emachine recovery disk run on new hard drive
Oct 06, 2009 | eMachines T6426 PC Desktop
Replacement of hard drive
The first link is to download the step by step instructions on how to replace the hard drive on your model. The second is the contact link for e-machine ,as I found no restore disk as a download.
http://www.emachines.com/support/service.html#eurpp
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2824
Apr 22, 2009 | E-Machines (T2824) PC Desktop
Emachine hard drive door will not open (how to repair?)
Assuming this means the CD drive rather than the Hard Drive (which doesn't normally have a link to the outside world).......
Unless something from outside is very obviously fouling the door, the problem is probably internal to the drive. With the price of replacement drives these days (shockingly low), I wouldn't even bother opening the drive to investigate what's wrong - I'd just put a new (probably higher spec) one in.
They're all a standard size and fitting and fitting a replacement is a "no surprises" job.
A.
Sep 17, 2008 | E-Machines eMachines Desktop PC
Emachine T5026 installing a new hard drive.
place the harddrive over or under the old drive.
a IDE cable most be connected to the harddrive and to the motherboard.
and a 4-pin power cable most be connected.
CS.
May 18, 2008 | E-Machines eMachines Desktop PC
eMachines eM250-1915 Netbook Logo
44 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
