My tv child locked how it open. - Televison & Video
What model of television is your ?
Posted on Jul 17, 2013
My tv is a Eurostar emerald it has locked. How it will removed.
  • laze Jul 17, 2013
    If you have the instruction manual of your television there you will find the number to unlock your tv :)
  • laze Jul 17, 2013
    Try with code 512 :)
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Jan 01, 2016 | Televison & Video
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Hundai tv child lock,cannot open the tv
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.To get more details, http://electronicshelponline.blogspot.com/
Nov 29, 2013 | Televison & Video
How to open TV lock, Panel lock and child lock of Crown Texla Television
As with all brands and models that have these features the information is never in the technical manual but is always to my experience in the owner manual--if no help there contact the company who made the unit.
Apr 16, 2012 | Crown Televison & Video
How to open child lock on cineplus LG TV manually as remote is not working
Try entering code 0000 or 1234 for the child lock.
Otherwise try holding down the DISPLAY key on the remote or on the front of the tv for 10 seconds to disengage the child lock.
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
My TV is on child lock how do I unlock please
  1. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
  2. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
  3. Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Read more: How to Unlock the Child Lock on a TV ' eHow.com http://www.ehow.com/how_4510749_unlock-child-lock-tv.html#ixzz12VdKs6Bt
Oct 16, 2010 | Televison & Video
Removing the Child lock when remote doesn't work
CHILD LOCK CAN ONLY BE REMOVED IF REMOTE IS NOT WORKING, OPEN YOUR TV AND CHECK FOR 8 PIN INTERGRATED IC..24C04..ANY NUMBERS LIKLY TO BE FOUND AND REPALCE WITH THE SAME NUMBER, IT WILL WORK
Oct 14, 2009 | Hitachi C21-FL21F 21" TV
Tv stuck on lock , model is SVLT150 SANSUI 15'' TV. I dont have the remote controller
Hi
Did you mean child lock? if childlock you need a remote control to open this tv..
Thanks!
Jul 08, 2009 | Sansui TVM1916 19" TV
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
Child lock on tv
i did child lock in my tv n my remote also not working plz tell me how to open tv now i
Jan 15, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
