Question about Freezers
Hygena fridge freezer APM6855. In holiday mode. Freezer ok. Ice in bottom of freezer .fridge not working
  • 447 Answers
Try defrosting freezer. If still not working, you may need to have unit recharged.
Posted on Jan 14, 2014
fixitallguy
  • 11 Answers
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
  • 86 Answers
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Posted on Jan 02, 2009
  • 400 Answers
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Posted on Mar 05, 2009
SOURCE: Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Posted on Sep 04, 2009
victorwod
  • 157 Answers
SOURCE: Siemens fridge freezer keeps sounding the alarm but freezing up
yeah and that is never a problem
Posted on Feb 20, 2010
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
The freezer cools half way top, below is warm.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 | Freezers
Sep 03, 2009 | Freezers
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Freezer ice making compartment stays in lock mode
the thermostat in the ice machine is not working. its most likely tha the icemaker is a FSP whirlpool it's a lot surer to just replace the hole head and be done with it unless you'd like keep dealing with it.
Mar 18, 2009 | Freezers
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
Jan 20, 2008 | Freezers
Freezers Logo
125 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
