Question about Refrigerators
Samsung refrigerator RFG298HDRS low water pressure from door dispenser
My Samsung refrigerator RFG298HDRS/XAA will only fill 4oz of water in 10sec from the door dispenser.I have a water softner & a reverse osmosis system.I removed the filter to see if it would increase the water pressure and it did not.What can I do to get descent water presure?
  • 262 Answers
SOURCE: Water/Ice Dispensers not working.
see if you have a filter in the ref it could be stopped up too
Posted on Dec 19, 2007
davidpsr
  • 222 Answers
SOURCE: Water flow in dispenser in door is slow
Probably calcium build-up in the water valve. If you can get to the valve, see if you can take the water line off and put a little Calcium/Lime/Rust (CLR or a similar product) in it. If you've got one of those syringes like you inject spices into meat and turkey, that would do the trick. You might also try an eye-dropper. BE SURE to flush the line throughly after you put the tubing back together. For safety's sake, flush it twice as long as you think you have to.
That should do the trick. If not, you may want to remove the valve and see if there is a calcium build up there. It's the 'bottleneck' of the water flow system, and I'm betting that's where the blockage that's slowing the water flow is. Worst case scenerio, buy a new water valve.
Posted on Jun 27, 2009
EllaWatson25
  • 725 Answers
SOURCE: WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Posted on Oct 10, 2009
jmgldsmth
  • 1889 Answers
SOURCE: ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Posted on Jul 22, 2010
espressonist
  • 1711 Answers
SOURCE: I have a Kenmore Refrigerator:
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Posted on Sep 27, 2010
Samsung RFG298HDRS bottom ice maker stopped making ice.
Sounds line water line inside unit that runs to the bottom icemaker is frozen.
Nov 13, 2015 | Samsung Refrigerators
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
No water when water filter is replaced for RFG298HDRS/XAA
You are not screwing the new filter in right/ it is not seating. I experienced the same problem; you need to "break the seal" on the new filter.
Apr 03, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
My Samsung RS267LBBP side by side has low water preasure at the dispensor after only three weeks after changing the filter. I've changed it three times with the same result. Also, I've noticed the ice...
with samsung refers the control board and ice maker have be updated Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
