Question about Kyocera FS3140MFP AllInOne Laser Printer
Turn on confirmation page
I have a user with a Kyocera FS3140MFP and I am logged onto the web interface and can not find how to turn rhe fax confirmation sheet on. Please Advise.
  • Kyocera Expert
  • 337 Answers
You need to turn that on at the control panel. you cannot toggle that option in command center rx
Posted on Dec 26, 2013
Paper keeps creasing during printing. have moved guides out as far as they go
Creasing is usually caused by pare skewing so guides must be as tight as possible against the paper if it's still a problem you will need a new fuser a unit more than likely
Mar 12, 2015 | Kyocera FS-3140MFP Plus Black & White...
Error type :setting
if scanning to email it means you have one or more smtp settings wrong usally its the host address or authentication user and pass
if its to folder its either the ip of the computer is wrong or the login info is wrong
May 13, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Can you increase Fax Memory for FS3140MFP
Sorry, but that is the maximum and standard amount of fax memory available for this model.
Mar 03, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Printing from auto feed leaving lines down side of page
if you mean making a copy from the automatic document feeder check the slit glass (the thin narrow glass beside the big platen glass) for debris, white out, dirt, etc... a small dot on that glass will make a line on the copy.
Aug 20, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Where is the was button
I'm guessing you mean the WPS button - "Wireless Protected Setup" - As far as I can see from the User Guide this router doesn't have an actual WPS Button - You need to log onto its admin web interface and browse to the WPS setup page - Press the WPS button on your client device (laptop, printer, etc) then Click the WPS button in the router's web interface and let them talk to each other to establish a secure connection - The WPS light on the Front Panel should then light up when connected - You can find a user guide at the following url:
http://downloads.linksys.com/downloads/userguide/1224642967100/WRT54G2-EU_V10_UG_combination_NC-WEB.pdf
Jun 14, 2013 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
FS3140 memory full
this can occur if jobs hang due to printer error (empty toner, jam, etc...) if the printer usually prints normally but displays that message when faxes are being received then you may need to reset or replace the fax board and update the firmware. you could turn on hdd RAMDISK mode in the command center. You could also add additional RAM
Feb 19, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Need to allow a telnet session thru a speedstream 5660 modem/router having a public ip and allow it to connect to a private ip on the internal LAN. how do i accomplish this?
According to the user manual:
Page 16:
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
Configuration Procedures
Status and Statistics
Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Dec 29, 2010 | Efficient Networks SpeedStream 5660 Router
Cannot find confirmation page "on off switch" Ricoh Afico 2035esp
User Tools/Fax/Parameter Settings. Personally I wouldn't mess with those, it's to easy to totally mess up the fax system if you flip the wrong bit switch setting. I threw my 450 programing guides away some time ago being that there's just a hand full of these things left in the hole country. I believe if you go to Ricoh's web site and go to the download page, you can download the fax user manual which if memory serves me (and it often doesn't), you'll find how to change the fax parameter settings.
Jul 29, 2009 | Ricoh Aficio 450 Copier
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Confirmation page from days earlier
check the device for an activity log option. you may need to check the user manual for this.
Mar 06, 2008 | Brother IntelliFAX 4100e All-In-One Laser...
Kyocera FS3140MFP AllInOne Laser Printer Logo
137 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
