Question about HP JBL Platinum Computer Speakers
How to plug in
I've gotten two speakers and a computer, a transtec to be precise, but I can't find where I need to plug it in. Could you tell me where I've got to plug the speakers in? (in the computer)
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
Dell Precision M6300 turns on and then nothing happens.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Dell Precision M6300 Notebook
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
Fix speaker on dell t3500
Easier to buy a set of external speakers. Just make sure you have a sound card that has a port to plug the speaker into. If not it's still easier to buy a PCI Sound Card and a set of speakers.
May 11, 2012 | Dell Precision T3500 Computer Workstation...
I recently purchased bose multimedia speakers. I can plug the iPhone into the control and the sound is phenomenal. When I plug the USB into my laptop (HP6535b) the speakers install, but the sound is...
xp was never designed to do that ever. my guess... and is true in vast cases with XP , XP is DEAD, as will be getting new drivers for new devices, see?
When I plug the USB what does that mean.
all i can tell as would HP, take that USB thing above
go the the makers web site, see that software, there,
do they have XP software, NO.
i bet they do not support XP
not only that all said was,.
what does that mean>/ its non specific so is useless. input
the only word there good id BOSE(tm)
they make lots of things, most things do not run on any XP
unless real lucky,
my guesss is the BOSE(tm) has its own sound chip
and needs its own SOUND chip driver to work
and if even you had that chip driver,
XP would get real confused having 2 sound chips in one PC
try this , go to DM , device manager,
and turn off the normal sound chip from HP.
on windows 10 we click the task bar speaker and kill the onboard sound chip that way, letting head phones USB work.
or USB external devices that have, 2nd chip.
see? running 2 chips at same time (sound) is never going to work
like having 2 TV's playing same time, chaos.
Apr 27, 2017 | HP Computers & Internet
Little to no sound from the left speaker. I've plugged a simular speaker in it's place, same result!
Check your computers volume mixer for a slide bar (balance) and set it to the middle.
Aug 29, 2011 | Kinyo SW-7352 Computer Speakers
I have a set of JBL Creature Speakers that I take good care of. However, one day, I knocked one of the satellite speakers off my coffee table, and subsequently that speaker only plays very faintly,...
Without seeing it it is hard to tell, but it could be that the speaker cone is out of the magnet hole, and is missaligned, in other words the voice coil could be sitting on top of the magnet instead of in the magnet hole... If you DELICATELY push on the speaker cone does it move in and out???
side view cut away of a speaker...
Aug 20, 2011 | JBL CREATURE II Computer Speakers
I've had my my Logitech speakers for a few months now and they've worked fine up until a few weeks ago. Now if I turn the volume up more than a quarter of the way the sound goes scratchy and...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Logitech X-540 Computer Speakers
Hi i need help
Try asking the people at fix-ya, they are trying to help me right as we speak.
Mar 09, 2008 | Logitech Precision PC Gaming Open Air...
HP JBL Platinum Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
