Service code for sharp ar-m256 toner replenishment
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Posted on Nov 10, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 07, 2016 | Sharp Office Equipment & Supplies
Sharp photocopy AR-M256 showing F2-58
if you are using third party toner and drum cartridge replace them with OEM
May 13, 2015 | Sharp Office Equipment & Supplies
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 09, 2015 | Sharp Office Equipment & Supplies
Sharp ar-m256 driver
Manufacturer: SHARP Hardware: SHARP AR-M256 Software name: SPLC Printer Driver Version: 0702a File Size: 5.82Mb (6103906 bytes) Released: 14 Mar 2007 Uploaded: 10 Apr 2010 Views: 319 Downloads: 58 System: Windows NT Description: SPLC Printer Driver for SHARP AR-M256
Oct 03, 2010 | Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Shart AR-M208N Toner Replenishing
Have you removed the seal from the toner before installing it in the machine? If so, make sure it's all removed. If that looks ok there may be a problem with your machine.
The 208 is a fairly new machine, you might still have warranty on it. I'd check with Sharp or with the company you bought it from for repair info.
Oct 15, 2008 | Sharp AR-M208N Copier
May 23, 2008 | Sharp AR-M237 Copier
127 people viewed this question
k24674
jasbo
jasbo
