Beko aa class 1000 rpm door won't open
The door won't open, I've turned it on and off at the wall and machine itself but I'm having no luck
4 Suggested Answers
SOURCE: i need a manual for
help how do i make the machine do a quick wash
Posted on Nov 07, 2010
  • 6277 Answers
SOURCE: how do i work the
Methinks you could do with a manual to help you!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Posted on Apr 04, 2011
  • 6277 Answers
SOURCE: My BEKO AA class 1000
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 20, 2011
Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4...
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Mar 17, 2014 | Washing Machines
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
This is my Beko 6kg a class 1200 rpm washing machine. I'm looking for the quickest wash. It has a quick wash button but I can't seem to find a quik wash. Like a 30 minute wash??
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
Apr 08, 2013 | Washing Machines
Beko aa class 1200 rpm washing machine will not drain **** on cycle
Possible that the program controller is not outputting to the drain .Check this link to repair the drain pump
Jun 28, 2012 | Washing Machines
My BEKO AA class 1000 RPM won't empty out water after washes
John C
Sep 20, 2011 | Washing Machines
I have a beko aa class 1000 rpm and i want to remove the soap drawer to clean it. how do i do this??
I've just spent about an hour trying to do the same thing! After a lot of internet searching I found an answer. In the soap drawer there is a blue section with a small groove in it. Simply press this down & the drawer should slide out.
Hope this works with your model too!
Aug 07, 2011 | Washing Machines
How do i work the beko AA class 1000 rpm washing machine i cant get it on a quick wash and it wont rinse
Good luck,
John C.
Apr 04, 2011 | Washing Machines
I need a manual for a BEKO AA class 1000 RPM WMA 510W
Sep 12, 2010 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Cannot turn on my Beko WMA520W AA class washing machine. Is their a lock or code?
nothing special.
select program, shut door, press start button. there is a pause of few seconds before starting
Jun 25, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
