Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Head showing errors c:31
    New Friend:
    Problem Solver:
  • 6 Answers
showing error c:31 mean your camera have defective mechanic, which one contain error? well, to make sure your problem try to inserting cassette and see the mechanical work:
1. when tape is insert it, before reel try to raising the tape, head will spin first.
2. after head is spinning then the tape will load
if your problem is in no 1 the head drum doesnt spinning, try to check the flex cable the top section of the head.
if head drum is spinning its mean your capstan is broken, try to change with a new one
thanks
otto
Posted on Oct 07, 2013
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
Dell error code 31
Open Control Panel and then Device Manager (or System, then Device Manager).
Look for a yellow balloon, this should show you which device is giving the Code 31 error.
Then you need to fix the problem by re-loading the driver.
Mar 04, 2015 | Dell Computers & Internet
It shows c:31 22
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 05, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Jun 18, 2010 | Computers & Internet
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Error messages / Manual useless
have you run a Head Cleaning tape thru it? definite;y try that...run it for 10 seconds at a time
May 23, 2009 | Sony Handycam CCD-TRV57 Camcorder
Error code C:31:42 on a Sony Digital Handycam DCR-TRV530
Here is the solution to your problem:  C:31:42 = FG (film guide) fault during normal drum operations. Load the tape again, and perform operations from the beginning! Hope this helps.
Fotobean
Jan 19, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
A Error code C:31:40
Please see the detail below for the said error code C:31:40eb129ed.jpg
According to the symptom this show that there are two faults
1- Mechanical adjustment is out.
2- Head is durty.
Solution:
1- Mechanical adjustment is required of tape loading section.
2- Need head cleaning.
Please contact any expert nearby to yoy to fix the problem, because mechanical adjustment is not an easy task that's why prefer repair man.
Thanks for using fixya.
Dec 23, 2008 | Sony Handycam DCR-TRV240E Digital...
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
