5552 W,S,Z,X,2,F3 keys not forking. Where could be the problem, in keyboard or in motherboard? And is there any easy solution to fix that? Keyboard is clean, no water/food was on it. Ill be very grateful for any advice.
    Top Expert:
  • 12,223 Answers
1) us the system restore go to control panel , and use the last date know that was working , and fix it
or 2) download the driver from your manufacturer supply and uninstall the old ones driver corrupted and install the new ones update.
God bless you
Posted on Jul 17, 2013
  • 71 Answers
SOURCE: keyboard problem
If you can remove the keyboard from the laptop you can try cleaning the back of it with a que-tip and a small amount of rubbing alcohol. Most likely it will need a replacement keyboard, or you could plug in a desktop keyboard so you can at least use the computer until you get a proper replacement.
If you post the laptop maker and model number I can try to help you further.
Posted on Nov 12, 2007
listeur
  • 88 Answers
SOURCE: Keyboard keys not make contact
if you are smart enough to figure out how to pull out the keybord you can try gently rubbing the contacts to clean them and re-seating them, but probably are better off getting a replacement keyboard for the laptop- as they go for 20 to 40 on ebay for most models.
Posted on Nov 24, 2007
IB4G2008
  • 3587 Answers
SOURCE: mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Posted on Feb 20, 2008
coldsilver20
  • 113 Answers
SOURCE: sticking keyboard keys on toshiba satellite L10
you could remove the keyboard but it probably wont do any good. They keyboard on a laptop is typically a solid slate with individualy key slots that can be individualy removed and replaced. simply pop the key off, use a alcohol swab and press firmly to replace....its just that easy,...and no tools needed!!!
it wil probably take an hr or so to finish all the keys.
Good Luck!!!
Posted on Mar 11, 2009
  • 406 Answers
SOURCE: how to clean Samsung NC10 keyboard
I recommend you to change the Keyboard from authorised service center.
Else you have to open the screws from the base and and remove keyboard. and clean it thoughroghly.
Posted on Jul 12, 2009
P is stuck on hp laptop
did someone knows how to fix an action replay dsi;
because i have got 2 action replay dsi.
Dec 30, 2012 | Computers & Internet
F keys do not work f3,f4,f5,f8,f9
You will need to replace the laptop keyboard, go to www.ebay.com Type: make and model of laptop, refine search to keyboard. It would not hurt to use an external keyboard to be sure.
Apr 30, 2012 | Dell Inspiron 15 1545 Notebook
How do Iget the question mark symbol from the keyboard key to activate I need the right side function on the keyAspire 5552-7686
Hi
if you are using an english keyboard then if you hold down the shift key and press the ? key then you should get the ?
many thanks
Jul 13, 2011 | Acer Aspire 5520-5908 Notebook
My display dimming keys are not working, all other keys are working it is the f2 f3 keys,
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Jan 21, 2011 | Computers & Internet
Several keys on my Acer Aspire 3680 (P, Q, TAB, etc.) have stoped working. What is wrong, and how can i fix it?
you can check ebay for a new or used working keyboard and replace it yourself. most keyboards are easy to replace. MIght be some screws on the bottom holding the keyboard to the laptop or the up area of next to the LCD will pop off and there will be screws under that to allow you to replace the keyboard. just be careful with the ribbon connection on the motherboard some of these are thin and easy to break.
Jun 30, 2010 | Acer NSK8458AN Keyboard
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
MS wireless 1000 keyboard function keys
The "F Lock" is a dual function key,try pressing this key and should fix your problem.
Miklo
Jan 26, 2010 | Microsoft Wireless Optical Desktop 1000...
Keys on my SK9920 stick...how do I clean it?
The same thing happened to me with my gateway keyboard. The f2, f3, and f4 keys were stuck down in the keyboard itself. I just wanted a quick fix, so I soaked a paper towel, rung it out, and cleaned the keys like that, all the keys work wonderfully now
Dec 28, 2008 | Gateway 2520915 Keyboard
F Keys
yes you can fix it ....it sound to me like a bad assambly case..all you got to do is open by tne back carefully acomodate de parts in good position and that is..be carefull if you put de keyboard in your lap all the keys will coming out with little skill you will do it...good luck and rate me
Jan 02, 2008 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
