Toshiba air conditioning fault codes
Air conditioning is showing error e5 unit is cool easy KFR-32GW/XC1 by Toshiba doug
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Posted on Jun 26, 2010
  • 266 Answers
SOURCE: Model: KFR-32GW/Ac Will not stop leaking
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Posted on Aug 08, 2010
  • 30 Answers
SOURCE: Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Posted on Aug 14, 2010
hvac1960
  • 2133 Answers
SOURCE: Yonan Split Air Conditioning System
F6
ambient temp.
sensor of outdoor
fault
1?Check whether the resistance of sensor is normal,
otherwise replace it.
2?Check whether the sensor wire is short circuit or open
circuit, and whether the plug is well contacted, whether
there is welding off or rosin joint on the electric control
board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components
or integrated circuit is damaged, the electric control
board should be replaced.
Posted on Dec 02, 2010
kendji9
  • 111 Answers
SOURCE: My Hitachi Utopia air con shows fault condition AO
it must replace the controller in macine, must service in developer/distributor center
Posted on Jan 22, 2011
Why is e5 showing on my 15000 frigdare window unit
Ive seen ES, in two sites http://www.doityourself.com/forum/air-conditioning-cooling-systems/532071-frigidaire-ac-window-unit.html
http://www.searspartsdirect.com/window-air-conditioner-repair/error-codes/frigidaire-window-air-conditioner-error-codes.html So I'd tend to agree with the majority.
Mar 14, 2015 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Mec portable air condition shows E5 on the screen after i on the air cond about 15-30minutes. Once it showed E5, cool air was not feel but just like fan air. what is the problem?
MEC portable aircond show P1 after on in a 1 and half hour. Once it showed P1, cool air was not feel but just like fan air. what is the problem?
Jun 02, 2012 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
Jun 12, 2010 | Heating & Cooling
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
No manual available, the error code is E4. model KFR32GW/e, seria
This is a manual I found, but I am not quite sure about the manufacturer, since you did not mention it.
It sounds like it may be low on refrigerant, if it is working but not cooling well. I could not find an error code in the manual.
The answer would be to add refrigerant to the system.
https://www.manualslib.com/products/Gree-Kfr-32gw-Naa12-E-3780653.html
Aug 12, 2017 | Emerson Quiet Kool 6GC53 Air Conditioner
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
