Question about Canon PIXMA MP600 all-In-One InkJet Printer
Scanner ribbon Hi I have had to strip down my printer dew to a lodged object blocking the paper feed. In doing this the scanner ribbon has become detached from the main pcb so when I turn the printer on I get the 5010 code coming up. I need help to try and locate where the scanner ribbon needs to reattach. I have spent hours looking but cant find out where to plug it back in. Any help, pictures etc would be great. Thanks in advance
    Scholar:
  • 134 Answers
Hey there i have found a service manual that has parts catalog too and it will help u locate where the ribbon goes ond other problems u can download it from the below link:
http://goo.gl/PmouM
Good luck
Posted on Jul 21, 2013
DX5000 says paper jam but isn t one
First of all, we need to establish that there is nothing causing an obstruction, this may not be prominent on first glance. Things like hair clips, staples, pen lids and all other small objects can be dropped into the paper feed unnoticed.
Step One: Removing the power cable.
Please remove both the power and data cable before attempting any of the following solutions.
Step Two: Foreign Objects.
If possible, use a flashlight or inspection lamp to illuminate the paper feed section (located at the rear of the printer where paper is inserted) and check for any foreign objects. Sometimes even having a thorough look won't uncover objects stuck further down, in this case (Do not attempt this if the printer is large and/or heavy),taking great care, you may need to turn the printer upside down and give it a little shake to dislodge the blockage.
Step Three: Only attempt if step one did not resolve the problem.
If the error occurred after a genuine paper jam, it is possible that there may be one or multiple pieces of paper still lodged in the printer, these could be in the rollers (The small cylindrical feeders that the paper passes between) and sometimes stuck underneath or either side of the printhead itself (The printhead assembly is the unit the cartridges are placed in). These pieces of paper may be covered in ink which can make them very hard to spot, arming yourself with a flashlight and a pair of tweezers should make things a lot easier for you.
After steps One and Two are completed, reconnect the power cable and turn the printer on, if this still doesn't solve the problem and you are sure there is no obstruction then move onto step Four.
Step Four: The Encoder Strip
If the paper jam error still persists, it is possible there maybe dirt, ink or grease on the encoder strip. This problem can confuse the printer and can often trigger the paper jam error, this is due to the grease/dirt blocking the laser that is shone down the encoder strip.
To clean the strip, you will need a small cloth (preferably a lint free cloth like those used to clean spectacles).
Open the lid of the printer where you find the ink cartridges and printhead, running all the way along and almost dead centre, you will find the encoder strip, a semi-transparent strip of plastic. If it looks dirty, place one hand on the left end of the strip and hold firmly (this is to prevent the strip from stretching or breaking when you clean the dirt with the other hand). Gently rub the strip horizontally up and down the entire length, taking care not to assert too much pressure.
Once this process is completed, you may reconnect the power and turn the printer on.
I hope this helps solve your issue. If however you have any further questions please feel free to Tweet us @RefreshCarts or post on our Facebook page http://www.facebook.com/RefreshCartridges
Alex Minifie
Refresh Cartridges
Aug 13, 2013 | Epson Office Equipment & Supplies
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Getting a black vertical line on paper when using top feed, does not do it when placed on scanner
1. Check the Automatic Document Feeder for any debris (paper, lint, etc.)
2. Open the top cover to reveal the platen glass.
3. Look to the far left, you'll see a thin strip of platen glass seperate from the bigger plate where you place flatbed scans on.
4. Check the thin strip of platen glass for any marks (correction fluid, marker ink, etc.)
5. Wipe glass with a damp cloth and some Window cleaning detergant.
Does the line still appear now when you scan using the ADF?
BD
Sep 22, 2010 | Brother DCP-7020 All-In-One Laser Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
My paper feed is pulling down on the right side and jamming
there are many cause to this problem but the two most common are these....
1, a paper clip or or other small object has got lodged deep inside the sheet feed ( or in one case a hardened bread crust)
2, It's just dirty. Many machine if left uncovered when not in use get clogged up with pet hair and general household gunk.
The answer for both is the same. It need stripping and cleanng out. Any express centre should be able to do this.
Jul 10, 2009 | Epson Office Equipment & Supplies
Cx3650 Problem with paper feeder
There could be an issue with the gear inside your printer now that is why it is not feeding the paper through properly anymore. Please try this basic troubleshooting steps:
Turn off the printer. Disconnect the USB cable from your printer. Open up the whole scanner unit to see if there are objects blocking the way of the printhead or if there are any objects down the paper feed area. Check if the cartridge cover is closed properly. Toggle the paper guide left to right back to the proper position. Load 10 to 20 sheets of regular paper into the printer. Turn the printer back on. Do a standalone copy.
If it does the same thing, please log on to support.epson.com. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
May 12, 2009 | Office Equipment & Supplies
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
