Question about Garden
How to set timing for honda pressure washer gcv160
woobie dog
  • 1273 Answers
SOURCE: 2-yr old troy-bilt pressure washer with honda
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Posted on Jul 17, 2009
SOURCE: Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Posted on Jul 31, 2009
  • 174 Answers
SOURCE: Honda GCV160 Engine Won't Start
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
Posted on Aug 08, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
  • 68 Answers
SOURCE: NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Posted on Jun 16, 2010
Trying to get a manuel for Honda power washer GCV 160 lan5rn81
l
here is the link for the honda GCV160 engine. http://lawnandgarden.manualsonline.com/manuals/mfg/honda_1_2/gcv160_2.html
There must be another model number for the pressure washer. Check the pressure washer again and search that model on manualsonline.com
Aug 01, 2014 | Honda Garden
Low pressure
faulty pump. check each valve for obstruction or fault
Apr 05, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Small clear hose on Honda power washer
Sounds like the hose that goes into the detergent bottle.
Mar 21, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Gcv160
Clean it up real well and try again. Most likely the oil is from the motor being put in a position that allows the oil to run into spots that it is not supposed to be in.
May 17, 2013 | Honda Black Max 2600 PSI Pressure Washer
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
Honda gcv160 wont dispence detergent
it will not draw soap while using pressure take out the nozzle or use the large black nozzle
Jun 09, 2012 | Craftsman 2600 PSI Honda Powered Pressure...
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
Hello
Aug 08, 2009 | Karcher 2500 PSI Pressure Washer
How to repair a hole in the wand tubing for pressure washer
my Honda ic2 ran greet, then all of a sudden it started to slowly shutting down,
i restarted it. and it ran for about 5 min and shut down. i did this 3thee to four times do i need a gas additive or what
Apr 27, 2009 | Garden
Mar 17, 2009 | Campbell Hausfeld Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
