Ricoh printer c220 error sc542 & ricoh 4110 printer error sc541
Cogz
  • 1326 Answers
SOURCE: about ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Posted on Apr 23, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
ginko
  • 19396 Answers
SOURCE: ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Posted on Nov 19, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
SC542 PROBLEM IN PRINTER
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Oct 31, 2014 | Ricoh Aficio CL3500N Laser Printer
Sc542 cl4000dn
likely to be toner on your thermistors - clean the thermistors and pick off pawls for the hot roller - i'd also check your web roll to make sure its not dry and make sure the press roller cleaning roller is clean
Oct 14, 2013 | Ricoh Aficio Sp 9100DN Printer
GIVING ERROR CODE SC541
SC541 or SC542 is a fusing problem clean /check/ replace thermistor 1 and 2 and fuser fuse 1 and 2, these are located on your fusing unit
May 21, 2011 | Ricoh Aficio 1035 Copier
I have ricoh aficio mp1600 & this machine is error occoured Sc:542 how to solve this problem?
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Dec 03, 2010 | Ricoh Aficio MP1600SPF Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
About ricoh copier problem
Apr 22, 2008 | Ricoh Aficio 450 Copier
29 people viewed this question
k24674
jasbo
jasbo
