Question about Sony Televison & Video
Red flashing light
My TV is a Sony Wega KV-BZ14P40. Recently it started turning on with the usual green flashing and it settles but very shortly thereafter it starts to flash in red colour. It flashes red 5 times in a row, pauses for about 3 seconds and flashes 5 times again over and over. The picture is also dull especially when I just turn the TV on. Can you help please?
    Top Expert:
  • Sony Master
  • 75,424 Answers
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Jul 17, 2013
1divebum
  • 12 Answers
SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
Posted on Sep 23, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
jerryg50
  • 1689 Answers
SOURCE: Sony KV-28HX15U
Most likely the flyback assembly, and or the horizontal output transistor failed. There is also a possiblity of some other faults that are putting the power supply in to the protect mode.
If there is a scan failure, it is possible that there is also some damage in the power supply.
The set will have to be serviced by a TV service tech.
Jerry G.
Posted on Apr 19, 2008
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Posted on Feb 06, 2009
  • 4234 Answers
SOURCE: Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
Posted on Feb 24, 2009
RED FLASHING LIGHT
sir
these are the causes for 5 red blink in your modal
Video OUT (IC1545) is
faulty. (A board)
• IC001 is faulty. (A board)
• Screen (G2) is improperly adjusted
thanks
Oct 03, 2017 | Sony Televison & Video
Sony wega
1. the lamp may need to be replaced .
2 chk if the door for lamp replacing the lamp is well shot, if not tv will not start.
Jan 21, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
Sep 28, 2010 | Sony FD Trinitron WEGA KV-28CS70 28" TV
Sony wega turns itself off
Try to resolder the main board, cold solder only.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Televison & Video Logo
160 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
