Question about Hensoldt Optics
Repair My Hensoldt Zf24 model 2 (focusing knob) has some internal problem causing spreading of Group up to 40 cm at 200 meters. It has not been exposed to external violence except recoil from maybe 1000 rounds 7,62x51 ammunition. May I send the Scope to you for repair?
  • 243 Answers
No. Send it back to the manufacturer.
Posted on Jun 24, 2014
  • 8 Answers
SOURCE: 8x32 swat scope
It's not a high end scope. Most times you're better off buying a lower power scope of better quality and you'll still be able to see more clearly than with a higher power yet lower quality scope.
Consider that 6x, and lower power, scopes were pretty much standard for WWII snipers, and that fixed 10x is still an accepted power level for snipers these days.
Posted on Nov 26, 2008
Doktir
  • 55 Answers
SOURCE: AEG triweaver rifle scope 3-9x40 can be combatible
If it fits the rail, it'll work, just make sure to adjust the scope to absorb the recoil, by target practice at about 60-80 ft, and adjusting the scope up or down until it absorbs the motion of the recoil. Hope that helps!
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: Tasco PDP6 (40 mm) turns off during shooting
gfcerhv
US UR BRAIN WAH WAH HAH HA!Haghfsdjhfrvehj jjhvncczxfc xzvghscv cxghv
grcfkcgjipojtyujhdfavghsdfghvefagibqfbghijvqhubjvfvjhurqcdqlujik.vfiuqlkjvcilguhb.tl.tkfvilu.k\vqu;.jvqu;lt.qvwiul;qwtuloqwvlj.kvhjlvqw;qglvgurhwevuj
Posted on May 07, 2009
agent91
  • 2100 Answers
SOURCE: Need information regarding my Jason Model 962 Rifle Scope
If you need info on sighting in a scope, go to my profile, I have it listed in my tips.
Posted on Feb 21, 2010
  • 18 Answers
SOURCE: Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Posted on Mar 11, 2010
Lenses on K10D do not focus correctly on low f stops eg; f1.4/2.0 but focus well on higher f stops eg f11. On the lower f stops the lenses are back focusing by around 4 to 5 cm. Any help Thanks
Although you think the lens is in focus, when stopped down, I know it is not.
There are enough articles that tell about Depth Of Field, but I give a short explanation.
The DOF from a 50 mm lens on a APS-C camera, when set to f /1,4. when you focus on 1 meter, is just 2 cm when on f /4 you have a totoal of 6 cm and on f /11 it is 11cm. So wen your camera / lens combination has a back focus of about 5 cm, it will come within the 11 cm you get in f /11. Still the picture is not in focus, but you see what you want to see sharp.
I searched through the complete manual, scanned the review on Dpreview and searched the site from Richo, but noting to find about correcting back or front focus. on the K10D. Perhaps, because in the days this camera came on the market, they thought the photographer who uses f /1.4 lenses is used with manual focus.
I'm, not sure, but perhaps someone on the Richo / Pentax service centre can tell you, if they can correct the setting for your lens.
To my experience, the front or back focus is in the camera. (the six or 7 lenses I use on my camera, all have the same back focus, but my Nikon has a setting to correct that.
So if you want to use your lens without any change made to your camera, there is only one option, focus manually.
Sorry I could not find more.
Success
Mar 08, 2014 | Pentax Cameras
Focus knob turns but nothing moves
The Celestron manual for this scope has nothing to say, but on the underside of the focuser assembly, between the 2 focus knobs, you may see 2 screws.
They might be thumbscrews or some other screwhead type. One is the adjustment for the focuser internal clearance, or looseness, and the other is a focus travel lock.
If present, try backing both off 1/2 turn from tightness, and then experiment to see which is which. The focus lock will have no effect until tight, when the focuser will cease moving, as is now. The other screw will gradually remove looseness and rattle from the focuser until it just moves smoothly, with no back and forth loose feeling at the knob.
If neither of these screws is visible you will have to take it to a binocular and telescope shop, where they should not charge much.
May 02, 2012 | Celestron Optics
8x25 minolta compact bionoculars center focus knob will not turn. Have taken screw off center knob and removed 4 rubber strips on bionocular body and looks like allen? screw underneath. No obvious way...
They don't make these things easy to take apart, or fix. Here's your best shot- take it into a camera repair shop, and see what they say. Some tech might know what you have to do to get it apart, or if it can come apart without damage or special tools.
Unfortunately, only the repair techs know how, and there aren't too many (if any) of them, since they often just charge a set amount and send a refurbished or new pair to the customer.
Wish I had a more specific answer, but good luck to you, and with just a bit, you'll figure this out.
Sep 20, 2010 | Minolta Compact Binocular
Plank of wood 2 metres long. cut into two lenghts. longer piece is four times the lenght of shorter piece. how long is each lenght?
It is solved by writing an equation
If the shorter piece is y cm, then the the longer piece would be 4y which is four times the shorter length. The total of these 2 together is 2meters or 200 cm, Now write the equation (2 pieces together is 200cm)
y + 4y = 200
5y =200
y =40
Since we have taken the lengh of shorter piece as y,
Shorter piece=40 cm OR 0.4m
Longer piece =160cm OR 1.6m
I have written the steps in detail for you to understand the process
Good luck
luciana44
Longer piece= 160cm
Feb 28, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
2000 ford focus no.2 cylinder repair tune up
more information please ,like mileage-compression.has any work been done before ,is it a californian model
Dec 03, 2009 | 2000 Ford Focus
I need data sheet of the internal workings of 12" MEADE LX 200 (SCHEMATIC, REPAIR MANUAL, PARTS LIST)
Go to the LX200 Yahoo Group. They have diagrams in the files which you can access if you are a member of the group.
Meade has manuals on their web site here:
http://www.meade.com/manuals/index.html
Oct 04, 2009 | Meade LX200GPS Telescope
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
CofferMaker won't brew coffee properly
Sounds like maybe the temperature sensor is cutting it off too early. This is an expensive ($200 US) pot so I would contact the mfr. They might have a quick solution.
Feb 25, 2007 | Alfa CM-110 Coffee Maker
Optics Logo
37 people viewed this question
Top Hensoldt Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Hensoldt Optic Expert? Answer questions, earn points and help others
