Question about Transcend Electronics - Others
I can't access my transcend 8GB pendrive.and light is not blink.what to do?
    Champion:
  • 221 Answers
Go to http://www.transcend-info.com/Products/online_recovery_2.asp?LangNo=0
Posted on Dec 25, 2013
  • 70 Answers
SOURCE: i have 8GB pendrive of transcend. when ever i want
format it by dos
start>
all programs>
run>
type cmd
format it by
format g:(you type in ms -dos)
if you drive is f then
type
format f:
Posted on Mar 28, 2009
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Posted on Jun 21, 2009
SOURCE: Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Posted on Jul 06, 2009
sodeep
  • 3267 Answers
First
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
However if that does not solve your problem try this
Thats all...
Posted on Jun 24, 2011
abdulkarimap
  • 149 Answers
SOURCE: Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Posted on Dec 30, 2011
Hii i have JF V30 / 8GB Transcend pendrive.
Try finding a little switch on the pendrive, it'll be pretty tiny. This switch determines if the drive is read only or writeable. If not you can try disassembling it to find the switch. Check your manual if it says anything about a read/write switch.
Jun 24, 2010 | Computers & Internet
My transcend 8gb pendrive is not working. when i
hi, try to format the Pendrive and run scandisk command.
right click on pendrive > properties> choose format and when format is finish use check disk.
Jun 14, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Transcend pendirve of 8gb
your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
If the above method is not work
try to format in other operating system like vista or in 7
but not in xp because in vista and 7 you can force format your pendrive..
Sep 19, 2009 | Transcend T.sonic 612 MP3 Player
Transcend JetFlash V10 -8GB when opened shows ''insert disk''
your pendrive is out of order Transcend JetFlash V10 -8GB whenever you purchase a pendrive only
buy a 1,2,4GB
Jul 22, 2009 | Electronics - Others
8gb Transcend Pen-drive is not getting detected
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Jan 13, 2009 | Transcend (589307) Media
Electronics - Others Logo
162 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
