Question about DeLonghi ESAM6600 Espresso Machine
Ground coffee granules in cup
About fifty percent of the time when I pour a coffee (either via the short coffee, long coffee or latte functions) I'm finding loads of ground coffee in my cup to the extent that occasionally it's unprintable and I have to throw it out. Is there anything I can do to resolve this problem?
Are the pucks solid or loose in the grounds container ?
Probably the diffuser needs greased - or 25quid gets a new one
Posted on Feb 21, 2014
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: ECAM 23.450: I was accidently
From what we can understand the gound coffee have move in the grinder plates. If this is the case you need to udjust the grinder to more gross coffee. try to vacuum again so you get out some more grounded coffee. Then use some beensand try to make some coffees. The coffee will run fast but this will help to remove all the grounded remains from grinder. After a few coffees you should turn the grinder udjustment back to it original place. Take care tha you turn only one to two step at a time perform a coffee and then you can turn again the grinder to more fine.
You can also remove the whole brew group and wash it well so everything will be as before.
Posted on Jul 26, 2011
espressonist
  • 1711 Answers
We beleive that this is the same question as the previus we jus ansewr
My espresso machine no longer grinds the coffee beans. It did this morning it made two lattes, but tonight it isn't grinding.
Oh you must be upset that this has happen. I had something similar to this happen and what it needed was a good old fashion cleaning out. Be sure to clean all the parts and remove any old beans left in the machine. Run some vinegar through the machine to clean the fluid containing areas until you get a clean release into the cup. Run one more water through and I hope this fixes the problem for you.
Jun 23, 2015 | Krups EA9000 Barista Automatic Espresso...
What is the best coffee machine for home use?
I have seen for one of the site that shown me five best latte machines in which I liked De'Longhi Pump Espresso Machine as it has a number of benefits and best features that anyone can ever have at there home to get the best latte on there coffee. You can also have a look to this site to get the best Best Latte Machine for your home use.
Oct 03, 2013 | Keurig B60 Coffee Maker
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Nov 08, 2010 | Keurig Platinum B70 Coffee Maker
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
How many oz of expresso when making a 2 cup with the machine in a measuring glass . i bought two measure shot glass to make a perfect cup of latte. i know it says 24 seconds
For every cup of espresso we mean about 25cc to 30 cc and you have to use from 7 to 8 gr of groud coffee per cup according to the coffee blend and how strong you wand the aroma of your coffee. The running time for making either one cup or two cup with apropriate filter is about 24 to 30 sec maximum.
Good luck
Apr 18, 2010 | Breville ESP8XL Espresso Machine
I have just bought a Delonghi 680M. When I press latte not enough milk flows out. The cup only fills up about 2 inches and then the coffee pod starts.
The coffee machine has standard settings for each program. What you seem to feel is not enough is the standard setting for Latte. You can always set it to your desirable quantity, either for milk or for coffee.
Refer to your users' manual for more :)
Dec 06, 2009 | Nespresso Lattissima 660.R
What's the recipe for coffee ice cream
Ingredients:
  • 2/3 cup sweetened condensed milk
  • 2 tablespoons instant espresso powder
  • 2 tablespoons espresso liqueur
  • 1 1/4 cups heavy cream
    Put the condensed milk in a bowl and stir in the espresso powder and liqueur. In a separate bowl, whisk the cream until it reaches soft peaks. Fold the cream into the condensed milk mixture, then pour this gorgeous caffe latte-colored airy mixture into an airtight container and freeze for 6 hours or overnight. Serve straight from the freezer.
    This is the best procedure to make a coffee ice cream.
Sep 17, 2009 | Ice Cream Makers
Manual or instructions
http://www.focuselectrics.com/supportdata/L5750_CocoaLatte_CM300_ALL.pdf
Downloads complete manual as PDF. I lost mine too.
Sep 21, 2008 | Back to Basics CM300 Coffee Maker
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
DeLonghi ESAM6600 Espresso Machine Logo
99 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
