Error sc571 on nashua mp c2050 - Office Equipment & Supplies
Error code J020 on a Nashua Aficio MP C 2050
You must call Customer Care for the support. Entering the wrong way can permanently damage your printer. Just a call at +1(800) 243-0051 Toll Free
Apr 27, 2017 | The Office Equipment & Supplies
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
I have an error on my gestetner mp c2030 with code sc222, please help me.
Problem with the yellow laser unit. Probably need a tech for that one.
May 20, 2014 | Ricoh Compatible 4 Color Set Aficio MP...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
k24674
