Prolink router when adsl line connected, and i tried for connect to the internet, unable to connect! im sure about,i paid the rental, and there is no any disconnection from my service provider! i hope that,my adsl cable has the adsl signal, i cant understand what is this problem, i thought to back up router,but i cant get router's configuration page! plz help me!
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
  • 341 Answers
SOURCE: Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Posted on Nov 26, 2008
obededom99
  • 24 Answers
SOURCE: unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Posted on Jan 21, 2009
raffaiel
  • 209 Answers
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Posted on Apr 26, 2009
govinda123
  • 2263 Answers
SOURCE: I am unable to set up my Linksys WRT150N router security
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Mar 13, 2010
I am having problem with my dsl router. An icon appears at the taskbar saying that I am connected to the internet but when I open a browser, it can't connect. I am using a prolink hurricane 9000p adsl...
The IP address of the router must not be the same with the IP address of you your hurricane 9000p adsl router/modem. Try to set the IP address of the other to 192.168.2.1 and the other to 192.168.1.1.
Aug 25, 2010 | Computers & Internet
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless connections won't connect!!!!
make sure if your using WEP or WPA or NONE if the wireless router has a security like WEP or WPA make sure you enter the right WEP KEY or WPA key if ask on your computer take a look for your wireless router setting and wireless setting on your computer meets and same..
or
might be on your ADSL or what ever line you have try contact your ADSL hotline or what ever Line you use might be they had connection problem
or
try using LAN if working. if not your ADSL Line or what ever Line you use is the problem
Hope it help you out ^_^
Jul 03, 2009 | Velocity Micro NoteMagix x30 Laptop
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Airport settings in Mac leopard
Make sure your ADSL router has wireless capability or wireless function. Verify that from your Internet Provider. If your ADSL router doesn't have wireless function, you need to buy a separate wireless router then cascade it to your ADSL router, from there your airport must be working fine.
Sep 09, 2008 | NetGear DG834G Router
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Jun 09, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
