Question about Garden
Gardenline gcs-2000s electric chain saw
Machine won't start
Editor925
  • 285 Answers
SOURCE: MY ELECTRIC CHAIN SAW
With an electric chainsaw, you only require chainsaw bar oil. There is plenty of brands of chainsaw bar oil available at most hardware or pwer garden tool retailers. Use this oil and not any other generic car oil or anything like that as you will run into problems. Chain bar oil is designed to flow and the higher quality bar oils are better designed to adhere to the chain and tooth components to keep heat on the bar and chain down.
Posted on Mar 16, 2009
  • 188 Answers
SOURCE: I need an owner's manual for a remington electric chain saw
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
Posted on May 27, 2009
woobie dog
  • 1273 Answers
SOURCE: replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Posted on Jul 07, 2009
dontbother10
  • 2220 Answers
SOURCE: mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Posted on Nov 15, 2009
  • 14 Answers
SOURCE: 16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
Posted on May 20, 2010
Where do you put chain saw oil ,in a gardenline electric pole chain saw
in the oil tank near the chain bar at the end of the pole
Sep 13, 2017 | Electric Garden
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have difficulty starting my Gardenline 49.3cc chainsaw. Please let me know what the correct starting proceedure is.
Genral starting procedure on a chain saw is as follows, put fresh fuel into the fuel tank, top up the chain oil tank,switch the ignition on, if the saw has a half throttle position on the trigger lock this, if the saw has a primer depress this as many times as it takes to 3/4 fill the bulb, pull the choke fully out, if it has a deco valve push this in, now place the saw on the ground with the chain brake on and crank the engine ( always have the saw body between you and the cutter bar,NO left hand starting, NO drop starting ) the engine will only fire once on full choke, do not continue to crank engine after the first fire or you will flood the engine, push the choke back in, crank the engine until it fires up and runs,release the chain brake and blip the throttle to release the half throttle device.
Jan 22, 2011 | Garden
What oil to use for a gardenline electric chainsaw?
All saw chains/bars use regular bar oil for lubrication and is available form home centers, hardware stores, and saw dealers. Good luck!
May 27, 2010 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
